CB350 stripped harness issues
sbelshe
Over the past few weeks I have been stripping down my harness as I remove alot of my components. I'm having a few issues and was wondering if anyone saw any issues looking at the diagram.
When my key is off, my battery reads normal voltage. When I turn the key on, the voltage immediately drops to about 6.5v and slowly drops from there. I can still get the bike to kickstart, but when I hit my aftermarket starter bitton, the starter solenoid click, but the bike doesn't try to turn over.
Attached is my wiring diagram, anybody see anything that could be causing issues? Thanks
How new is your battery? Its the Amps that crank it not the volts so you need a good battery to start. You can take apart the starting solenoid and clean up the contacts in there too. As well have you tried to crank the starter from the batter and by-pass the key?
Get a #8 gauge wire or better, press an end on both ends, bolt the one end to the hot lead on the battery, RED. then touch the other end to the starter connection on the top of the starter motor. If the starter turns the bike over then you probably have a short somewhere in your starting circuit.
Here are some diagrams I have used int he past too.
I bought the bike 2 months ago, and the battery is dated from August 2012. So it's only about 6 months old. I'd be surprised if the battery is bad as it was fine before I started the teardown. The draining issue started after I removed the kill switch. While removing it, I connected the black/white wire to black. I noticed that if I disconnect these two wires, the voltage holds just fine when I turn the key on.
I ordered a new solenoid and am waiting for it to arrive, figured it can't hurt to replace it.
I'll have to give the bypass solution a shot for the starter issue.
It sounds like a bad battery to me,
connect your car battery with jumper cables and give it a go (with the car OFF)
you need to keep lead acid (and lithium FE too) charged. while the LiFe don't lose their charge sitting,m if they get low they may not recover. Lead Acid will self discharge over time, and need to be kept fully charged when stored too.
If you take a brand new, fully charged lead acid battery and let the voltage go below 11.6 or so, you probably halfed the life and capacity. If a new battery goes to 0 volts, it is essentially useless. It may take a charge, but will have nearly no capacity, and be unreliable.
You sometime get away with these discharges, but usually not. the chemistry get's ruined when they go dead.
Randomly saw these images on the home page and its exactly what I've been planning on doing for my brat build. Can't thank you enough for the visual representations coffee.
My pleasure Reesa17. I started my latest build with 73 wires running from front to back. Now I have 13, a big difference.
Question. I am looking at diagram two and don't see a regulator in there. Where would it be positioned? After the rectifier?
that is a good question. print them out and take them to a shop. i am sure any tech will help you.
its a combined certifier/regulator.
The battery system on these bikes are very delicate. always double-check any changes as the components can only fail once ;)
few things that can be better in the diagram;
1) the grey wire from the alternator can be attached to the yellow one right at the alternator. that will give the battery some boost. The wire is there to give extra power to system if headlight is on. Could help with loading problems. The rectifier is basicly a diode bridge. It allows the current to flow only one way. (hence the arrows on the drawing) When you turn on the lights, the grey wire also helps by delivering extra current. The rectifier is in the system because the alternator delivers AC, and your system is DC. The alternator gives up to 60 volts AC, wich is divided by 2 at the rectifier (only half the currents goes thru) and then its leveled to 12.5 (max 13.8 ) at the regulator. If the system delivers less then 12.5 at 3000rpm something is wrong and you're unloading the battery. Anything above 12.5 and 13.8 AT THE BATTERY @3000RPM is ok, that means the above described components work like they should.
Then you're sure your battery needs replacing.
2) as you have no high beam anymore, i suggest taking out the brown wire from the ignition to the taillight. attach the brown wire from the tailight to the blue one coming from the headlight switch. That way, it's possible to ride without any lights on, giving the battery more boost to load.
3. Ignition basicly needs to make the red wire black, black is hot when ignition is on, so thats ok. im not sure about the black/white dotted wire from ignition to outerspace. remove it.
4. i strongly suggest putting the high/low light back on. When the filament dies, you're in the dark. better to have high beam than no beam.
5. the thick dotted black/white is your coil power. It charges the coils. I suggest keeping that wire (VITAL) as short as possible (no reason, just reliabilty) and with as less as possible conectors. Corosion is a biatch. attach it to black at the first time they cross on the drawing.
6. i would suggest using the proper wiring colors. In your drawing, for later checkups, but more importantly, on the bike. You wont remember that "extra wire" next month....
do one change at a time and check. if works, good. if not, go back.
for instance, you've attached the black wire (+) from the starter switch to green (ground)
might work for now, but will give headaches further down the road. Hmmm..was it ground or hot?
7. ground the green wire. IMPORTANT, the regulator needs ground to remove extra current from system.
For the rest it seems ok and i assume its just the battery. let us know what it was!
Wow, amazingly in-depth response Bert. That's the kind of insight that makes the forum amazing. Let me make sure I interpret all of this correctly, then I will update my wiring diagram.
1. Grey goes to yellow. I can then eliminate the yellow/white wire and the short yellow wire where hey are currently connected. I assume I should just tap the grey into the yellow and leave the rest of the yellow where it is as it connects to the voltage regulator and the rectifier.
2. Remove brown wire from ignition, check.
3. Not sure which wire your referring to as going into "outer space".
4. I actually have no intention of riding at night, I dont trust these midwest drivers, haha. Headlight is an emergency only asset.
5. Connection is correct, just shorten it, check.
6. The only reason I have the different colors on the diagram (for example blue and yellow) is because those are the colors of the wires on my aftermarket components. The headlight switch, the start switch, the tach and speedo light are all aftermarket. I figured if I kept all colors on there as well it would help me better understand connection in the future.
7. If the green wire on the bike not grounded already? I never actually followed it to a ground point but I assumed all along it was already grounded.
Thanks again Bert, incredibly helpful.
Ok based on Bert's reccos, here's an updated wiring diagram. Anybody see any potential issues with this or does this look good to go?
haha no problem, thats why we're here for ;)
roger on the aftermarket stuff, good call changing the colors on the diagram to those on the bike.
Almost there. The yellow and grey wires become one (yellow wire) at the alternator. The yellow wire then needs to be attached to the rectifier. That wire (together with the pink one, both AC) is your primary power from engine to system. If you dont connect that wire you will have no current flow and the bike will die when battery goes down. Its a commonly used trick in racing, because you can remove the whole flyhweel and such from the crankshaft for faster throttle-response and overall weight. downside is you need some spicy and pricey batteries every new race.
You say you never ride the bike with lights. Therefor, you could just cut the grey wire and only use yellow and pink to feed the rectifier. even cleaner. Downside is you can not run headlight for extended periods of time, say more then 30 minutes. It will drain your battery and heat up your regulator and wires. do not want.
the outerspace wire is the black dotted one from ignition to blue circle at the bottom. Is that your killswitch?
because killswitch should be between the black/white dotted line from spark-coils to where they become black.
for the rest, all seems fine. good job!
Bert, the man with the answers returns. I updated the diagram. I merged the grey and yellow wired out of the alternator and connected them to the yellow wire going to the rectifier.
I may as well leave the grey wire in, very minor difference and better to be safe than sorry.
The outerspace wire, that simply an extension of the ignition positions showing the change in connections based on where the key is. More like a "zoom" if you will. It's on the original diagram so I left it in for consistencies sake. Though, I can now see how it is obviously confusing, haha.
I think I'm all se here if I finally have this tightened up. I ordered a new starter solenoid and a gell battery just to go ahead and solidify the system.
As usual, thanks so much for the help folks.
yup, looks ok. Only concern i have is that the grey wire i normally used when much current is drawn from the system (headlight beam). when you dont run lights, its better not to use the grey wire. When you do use the grey wire combined with the yellow, the alternator produces to much current and thats no good as well. I can safely say yellow and pink are enough for engine and occasionial lights. How much amps is your battery? I'd go with anything between 8 and 12 amps. If you disable the starter, you can go as low as 2 or even none. i have those diagrams on my HDD if needed.
I just bought a BikeMaster MG12A-3A1, so it's 12 amps. I am leaving the starter is as I have wired an aftermarket starter button. It's not always warm here so I'd like a little assistance sometimes getting her fired. I may trim the battery to a smaller one down the road, but this is my first ever bike and rebuild, so I'm trying to take the safe routs right now and just get more acquainted with how everything works before I try that given these bikes finicky electrical systems.
Given your suggestions, I think I may just dump the grey wire. Again, I will very rarely be running a headlight, so If I can occasionally run it with the grey wire removed, that seems Ideal. Thought maybe it's not a bad idea to leave it in there an just unhooked with a ability to quickly connect in an emergency when I may need more use of the headlight. I may do that as it would be no more hassle and I can easily hide it.
Bert, your help was pretty amazing man. I finally feel confident in the wiring and am excited to wrap things up on the electrical system this weekend, thanks again.
Good to hear you're biting only as much as you can chew. Thats the best way to learn. Sometimes newbies here pull apart the complete bike including loom and end up with a pile of crap (in their eyes atleast) and come asking why it does not work the way it should. So kudos for your 'measure twice cut once' method.
I think you could just remove the grey wire. With a 12amp battery and the headlight on you could run the light for hours. The battery is more then competent to deliver the amount of juice, no problem. I'd advice you to recharge the battery afterwards (only if run for more than 1 hour with light on) because the charging system is only JUST competent enough to recharge the battery. So that way, you'll take some work of the hands of the charging system. This is al speculation and i'm 99% sure you won't have to charge it ever if you run the lights only now and then for a short period of time.
Im not sure how much amps your OEM battery was. You might want to change the fuse.
Once again, thats why we're here for. Next time i have a question and you have the answer ;)
Cheers!
