CB350 stripped harness issues
The current battery is a 12 amp as well, but it's a lead acid and it's weak. Good idea on the fuze, probably worth the 50 cents to change, haha.
If the OEM battery is 12amps as well, no need to change the fuse. You could check inside the fuse holder, as the connectors to the fuse are prone to corrosion.
Going great man, thanks. Got the wiring all tightened up last week. Heat shrunk, wrapped and hidden. Everything seems to work great. I upgraded to a gel battery and it solved alot of issues. Things I had been troubleshooting weren't even issues but were acting weird be size of the battery. Far as I can tell everything is wired right and good to go. All I have left to do is get the seat on and this sucker is ready to ride. I appreciate all the help again, couldn't have done it without all the advice.
I realize this is an old thread however I have a project bike. It is a 72 CB450. Do you guys think these schematics would apply to that as well?
If your engine has the same type of current generator, then yes. You need pink, yellow, white and green-red coming out of the engine.
If you have 3 yellows coming out it's not working. you'll need a combined rectifier-regulator then.
