CB350 surging
Deegan26
Hello all! This is not only my first bike but my first post as well. I'm new to the whole carburetor way of life (everything I've ever worked on is FI). When I first got the bike first thing I did was clean the carbs (what I thought was pretty well) and make everything look nice pretty. I added UNI pod filters (foam kind) fuel filters and rejetted to 105 and 75 mains to fix a slightly lean condition and the plugs look pretty good now. Left side looks damn perfect but the right side is still ever so slightly slightly lean. My question is I was out for a ride today (mostly highway) and everything started out perfectly but when I go to slow down at a red light after doing 60 for ~15 miles I pulled the clutch in and all of a sudden I started surging to about 5000-6000 rpm. Also when I let go of the clutch it will bring it back down to about 1200rpm but it'll bog down til the rpms bump up (then continues to surge) or it'll stall out. What would the most likely culprit be? Timing? Maybe I didn't get everything out of the carbs and something clogged a jet? Idle screws way off? I haven't had a second to look at it cause of work but I plan on taking advantage of the weather tomorrow and doing everything over. Just want to know a good place to start or what you guys think. Thanks a bunch!
-Deegan26
