CB350 Swingarm Bushings
sharp21
Where is the best place to get some? Its payday & I was going to order the tapered steering bearings, wanted to get some bushings as well.
Can I get bronze ones from the Honda dealer?
Will these ones from a 450 fit?
http://www.oldbikebarn.com/Street/1972-Honda-CL450-K-Scrambler-Motorcycle-Parts/Honda-Bronze-Swing-arm-Bushings
Thanks
S.
The CB350 has steel bushings installed. They work fine. The bronze bushings were made mostly to replace the nylon bushings on later CB360s.
I keep seeing that all the racer guys switch to bronze...
I guess I can get the regular ones at the stealership?
S.
If you could find the actual bearing code, you may be able to get them cheaper from a local bearing dealer.
i plan on having my brother make me some bronze ones for the 360 and later what ever other bikes i have. does anyone know where to find the bearing code? could be a cheap set of bushings in it for you.
Ive actually got a decent machine shop here at work!
Does somebody have the dimensions of the bushings they could post up?
S>
I just turned a set out of brass for my 500T, I don't know if they are dimensionally the same but I would be more than willing to give you the specs off the parts I made.
