CB350 Triple 6
Okay the local chrome guy got hurt and the guy an hour away wants $150 per rim NOTTTTTT even the local guy said that was nuts. But God is smiling apon me my powder guy is spraying some stools for a banquet hall and they are that nice chrome like color that JRK has YEAHHHH I'm cleaning up the rear spokes, rim, putting back together, trued, and then sprayed. Each for only $15 bucks. I'm just gonna have it all sprayed hub and all. Not as shiny as chrome but alot cheaper.
man really look at what powder he is using... it is VERY important that a poly clear is used on chrome powders... if not you will get a shinyer silver, but def silver... they come out looking good then when you clear them it will really dull it down... a poly clear will nto allow this, it will keep them shiny... and also protect the powder (metalic base)... alot of powder coaters do not like to use poly based powders as the gun needs to be taken completely apart and REALLY cleaned or it will just ruin the rest of your jobs... i have a few buddies that will actully mix the chrome and clear together for a decent effect... (i have never done this)
what i would do if i was in your shoes is this... have him shoot whatever chrome he has (i recomend patented chrome from powder by the pound, it is the best i have found yet, and you can use an ultra clear, not a poly and get away with it) but before he shoots your chrome have him do a dry mix... go to the local hobby shop and get the finest silver flake you can find... mix that into the powder before laying it down, I use about a table spoon per once of powder, for a mid to heavy flake, when shooting with dry mix you need to make sure that you regulate your current, and keep a 6 -8 in distance from the item with the gun.... (or else you will get clumping) i also hot flock the item (heat it up to around 150 before shooting) alot of people do not like to do this because it is hard to get uniform coverage levels (thicknesses) but on rims that will not matter, as you are clearing them as well and they do not need to meet specs for fitment.... that would leave you with siver rims that still sparkle in the sun, it would look TRICK as hell!!! i have been using a bronze flake in everything i shoot on my TX build and i have to tell you, it BLINGS in the sun!!!!
just to give you an idea of what Xtreme chrome looks like here is a GSXR wheel that i did and i then color matched the stripe when we shot it.... came out good. I did not do the color match (i am color blind if you can belive it) a buddy of mine did the match for me...
you mentioned earlier that you sealed the crankcases together with a silicone sealant.....hope it works! the best sealant is three bond 1211 and is found in different names from dealers. it is described as "grey semi drying elastic type sealant"
Same here Tod, but that sounds like what I used I was called ProSeal, it was grey, and made specifically for aluminuim. So it makes two of us now. I looked for Three bond but did not want to wait for mail order. I have found this little brown bottle from permatex which is a bush on liquid gasket which I wanted to post some ? about. But I dont have it now, and my back is killing so I dont feel like digging it out of the garage.
i used Permetex "the right stuff" on my entire motor and the (gray) stuff to work as my head gasket... i have only heard great things about these products and they are a hell of a lot cheaper than getting gasket kits
Just went over and dropped of my spokes and rims at YRC. Its a furniture store in San Luis Mexico owned by a very cool guy who has been hooking me up since I started this project. And Im SOOOO stoked right now he just got a cnc plasma cutting table so I'm gonna download sketch up and start designing some stuff. He's got all sort of tube benders no schrinkage no sand needed so thinking of popping out a whole frame or exhaust in the near future.
On the down side my after sand blasting my rear rim I'm unsure if it usable. The rust made it through to the chrome, so I have a small hole in my rim. Oscar had the guys weld/grind the hole up, but I think it may be thin in that area. I made a jig to hold all my spokes for powder coating because I wanted two tone wheels and then Change #202 I'v decided to go with flat black spokes and rim with a polished hub. Go figure I Might change my mind again. But I can use the jig on later project so no loss there.
Also got some new EMGO shorties and uhh the top eye is too small gonna have to have the center pushed out and the old ones set in. Unsure if they will go on Triple 6 or the Brat Bike. Pics later when I get home.
Took my wheel apart, trying to get her on rubber soon. My powder guy was not happy with me taking all my little spokes to him so I went home and drilled a tapped 72 holes in a piece of aluminuim so he could spray all of them at once. He was happy so was I.
As for the hub I polised it and painted the centers with brake caliper epoxy.
I went with all flat black for the spokes and rims. It was the most economical way of going. Next build I'm saving for aluminum rims and stainless steel spokes.
I think I got the lacing down the rear should be faster.
Got my new rear shocks might go on tripple six or on th brat bike thinking about it.
Another picuture of my spoke holder after powder coating.
man that looks great! i know what you mean on spokes, i have a setup alot like that as well, then some caps i put over the threads to protect them... can be a pain, you figure 80 spokes! ...
wheels look insane man! just great!!!
looking for tires now, and also someplace that makes hoses for my front brake. Has anyone ever use Maxxis tires? Yeah bro it was hell tapping all the holes. What do you use to cover the threads? Since I was going all black I just used the nipples, but down the road I might want to have diff colors on spoks and nipples.
Thx guys was unsure of the wheels at first. Hey JRK what can I use to touch up the powder coat if it gets scratched during tire install? I've decided to go with Wee Tods advise and go 90/90 up fron and 110/90 rear for tires.
first off if the powder gets scratched durring install it was not layed right or the wheel installer has NO IDEA what he is doing... i would hold him responsible for the charges of having the wheel redone... i have torn down, powdered, and re rubbered over 15 bike wheels and about 6 sets of car/truck rims... never once had issues with scratched powder on install... most of them will use the plastic adapters when they install the tires...
anyways, if you got a scratch there is not much you can do...
i have to warn you though, powder is not like paint in this respect there is really no touch up, you have to take it down and redo it, i know some guys use black perm marker to fix scratches in black... if you want to do it right
Hobby Lobby carries a "Plastic Solvent Cement" in a small 2 or 4 oz bottle with a brush cap. Ingredients you want are Methyl Ethyl Ketone. mix that with the powder you used till you get a paint like substance.... paint that on and cure with heat gun... BE CAREFUL NOT TO BURN YOUR POWDER THAT WAS LAYED DOWN FIRST!!!! also.. what color? if it is gloss black you can get touch up paint of appliance epoxy by the vents and filters at home depot... black epoxy paint is a spot on match for gloss black powder.
hope this help... i woudl be INSANE mad at the wheel installer though! for real!!! what if the wheel was chrome and he scratched it! they are responsible for that crap.... that is BS.
IMOALE, I just ordered a SS brake hose from Z1 enterprises. With all of the adapters and stuff it was kind of expensive but I think it will be worth it.
http://www.z1enterprises.com/catalog.aspx?pid=CM400T-1979-WB1
The different fittings and stuff can be confusing. The hose itself is threaded for JIC3. So to hook up the hose you'll need to get an adapter that goes from the JIC3 to whater thread type you're trying to hook up to your brake MC or caliper. The threads on my MC were 10mmx1.25. Then just get whatever size/shape banjo fitting you may need. I called them up to ask about this stuff and the dude I talked to was very knowledgable. He didn't know exactly what my bike needed but was able to tell me how to find out. They have pretty good customer service at Z1.
Thanks Colp. I called emailed them and they called back. I havent called them yet (z1). I think I'm gonna go with a Canadian seller in ebay Pro lines I think. 2 hose set, stainles, and custom length for about $50+. How much was Z1 if you don't mind telling?
