CB350 Valve timing question
alzcbz
Is the sprocket and camshaft aligned correctly in this photo?
And here is the crank on the LT mark
I've done this before, but something just doesn't seem right.
looks good if it was a tooth off it would not be that close
and when the bush blocks are in place it may line up even better
are you going to check the cam endplay ?
Yes. Will be checking end play. Nothing is bolted down yet.
Thanks
Assuming the camchain is tight, yes. Just install the advancer correctly and you're golden.
Just wanted to make sure the pin on the camshaft should be at 12:00 when the Horizontal line on the sprocket is lined up with the top of the camcase. All of this while the Left piston is at TDC.
Thanks again for the replies.
Yes, but the pin on the camshaft and horizontal mark on the sprocket will always be aligned together. I wanted to make sure the correlation between the sprocket and camshaft was right.
yup pretty sure you cant put the sprocket 180 out on the cam neither
