CB350 wiring guage size
The vast majority of wires in any motorcycle wiring harness are 16 ga.
I use 12 ga for headlight circuits and for a single ground bus running the length of the harness.
You should be fine with 18, but you increase the risk of burning the wires if you pull a little too much current. Say if you ran 18 to a headlight
What Sonic said. Only a couple things draw a lot of current, the headlight, and the horn. The horn is only an intermittant load, so overheating of the wire would not be a problem, but voltage drop over a small gauge wire would diminish horn volume. A headlight circuit with 18 gauge would overheat. 16 ga is barely adequate for headlights. That's why I use 12 ga, and I run it from a relay so that the headlight current is not running through the handlebar controls and the 16 ga wire that goes to them.
If you use 18 ga wire anywhere, make sure that you fuse it at 10 A. 16 ga you can fuse at 15 A.
Coils draw as much as 4 amps (V/R=I, 14 Volts / 4.5 Ohm = 3 amps, 14V/3 Ohm= 4.6 Amp).
ADC advice is good. I have as much as a 1 volt drop from the battery to the headlight. Thicker (lower gauge number) wire will reduce that. That makes the headlight stronger, and the Spark sparkier!
Even better, use relays. Heavy gauge wiring to Headlight and ignition switched by relays. The wiring for the relay coils can be 18 or even 20 gauge. So you have thinner wires by the ignition and handlebar controls, but great power source for the headlight and ignition.
With a stock vintage headlight, 18ga is fine. They generally run at 35W, so that's less than 3 amps.
Even with a 60W bulb you'll probably still be OK with 18ga so long as you don't make a long run of it and/or wrap the wiring with a lot of other wires.
When you increase the gauge of the wiring, you also increase the resistance and the heat. Length of the wiring run is also a factor in determining resistance. Furthermore, the number of strands of copper within the wire differs and higher quality wire will use a higher number of (thinner) strands. This will allow the wire to carry more current with less resistance.
Unless you're prepared to do the measurements, all of the advice here is just rule of thumb kind of stuff.
I use 18ga for most of my work and fuse it for 15A.
The 18 gauge wiring is perfectly adequate for the loads, but 16 is even better. But that is for a single wire to a single load. 15A is a high DC voltage load for an 18 or 16 gauge wire. The other item is Resistance per foot. The resistance causes the voltage drop and the longer the run of wire, the more resistance, greater voltage drop. That is why the stock Honda CB360 Wire has a 1 volt drop from the battery when under load.
I usually use 14Ga for my replacement, helps a bit, and I am not concerned with saving a few ounces of weight.
Most of the voltage drops come from the numerous connections and switches. Motorcycle Mfg's sure put a lot of connectors between the voltage source and the load. A good way to improve the system is to minimize connections.
My own opinion is that Sonreir is experienced and picks the right wire for the job, but not everyone has his experience and knowledge. If in doubt, go up a thickness (Smaller number on gauge).
Truth. You don't lose a lose much by going a bit smaller on the gauge, but the opposite is DEFINITELY not true.
