cb350 wiring question
jmeperu
where do the 3 wires coming out of the generator go to? i have two of them wired up correctly, i think, but i dont know where the white one goes. the bike runs nicely, im not sure if its charging or not. i put a multi-meter on the battery and reved the bike to 3k-ish and the voltage would stay the same or maybe go up a few hundredths of a volt.
on the old man honda diagram (which i used to make my harness) it shows the white wire connecting to the yellow wire from the generator thru some switch or relay. but i cant figure out what it is.
here is the diagram from OMH, the switch is at the top
http://oldmanhonda.com/MC/wiring350K4.html
please help me out.
are you sure it goes to the headlight switch? what does it do? can i just connect the yellow and white wires together?
i just dont want to fry anything, again. ::)
It compensates for the added draw when the headlight is switched on. You could bridge it to the yellow stator wire but I've read it may overload the charging system.
hmmmm. well i just did a 20 mile ride and i checked my voltage before and after the ride. 11.98v before and 11.36v after. im going to bridge them and do a test with headlight off and a test with headlight on.
