CB350 won't start
72texas350
I can't get my CB 350 started. It ran for a minute earlier and yesterday. It has new VM30 carbs that seemed to work fine after I put them on last week. It has gas. The timing is set correctly. The points are good. The key and ignition switch are on. The battery is low, but that has never been a problem before. The bike is kickstart only.
Anyone have an idea of what might be happening? Or what I should check.
I'm guessing this ^ if nothing else has changed. Honda twins do not like a weak battery at all, regardless if it is kick only.
I tried taking my battery to Autozone for them to charge it, but they can't I guess. I have a Ballistic lithium battery. The motorcycle battery charger they have at Autozone has the automatic cut off for acid batteries. It keeps stopping the charge on my batter around 7 volts. Any suggestions on charging it?
If you have jumper cables, maybe you could hook it up to your car's battery. At least you can do that to get the bike started.
That won't ruin the battery, will it? I thought about doing that, but I wasn't sure if it would kill my battery
Should depend on the voltage I believe. Both batteries are 12v. If you have a meter you can check quick.
Re: Re: CB350 won't start
Your battery is dead. Like kaput toast done finished. Can't discharge a Li battery under 10v, it kills the battery.
I jumped It is working now and holding a charge. I hope it isn't dead. I haven't used it for more then 30 seconds since I got it.
Now it's starting, but my left cylinder isn't running. It's getting gas and has a brand new plug. What the heck?
Rich Ard said:
Is it getting spark? Is your battery holding above 12V?
It seams to be getting spark on and off. The battery is holding more then 12V, but I died again when I was out testing the bike. Could it be the charging system?
Try it again with a conventional battery, bet it works ::)
I recently touched on a Suzuki "Tempter" that sounded like it was running great, but turned out to only be running on one-cylinder. I unplugged the right spark plug and it didn't change at all. Sounded strong. It would, however, spark the right cylinder when I rev'd it high enough for the charging system to supply enough power.
The battery was winded from constant cranking. Rev it to about 3k and pull a spark lead, stumbled and died just as expected.
You don't have a volt-meter handy? I've learned that licking these posts does more than just taste funny...
I got a chance to test my bike today. It is definitely the charging system, not the battery. I'm not sure what part yet, but the battery is not being charged at all. I threw the battery on someone else's bike today and it worked fine
