CB350F Carb/Points help
jas134
So I have almost completed my entire build of my 1973 CB350F but ran into a couple things while tuning the motorcycle after I had it wired and running.
I started with the valves, set them to the correct gap, adjusted the cam chain, then moved to the points.
Following my repair manual I turned the crank to the F position for 1-4, and adjusted the 1-4 point to the correct gap. Next I moved the crank to F position for 2-3, and the 2-3 point had no gap at all.....
I assumed the 2-3 point should have same gap tolerance as the 1-4 point as stated in the manual, so I opened it to the .016in gap. So now both points are open when I have either in 1-4 in F or 2-3 in F. Is this normal? if so how did the bike run with no gap at the 2-3 firing position?
Carbs:
I had rebuilt the carbs with new keyster kits, but took the carbs off to replace the main jet with an 85 instead of an 75 because I am running pods and homemade baffled drag pipes (anticipating lean mixture).
When I was replacing the main i figured to check the float bowl height. It looks like the keyster float needle is longer than the OEM and the floats were all at ~26mm instead of OEM 21mm when the float first contacts the needle.
I tried bending the float tabs to make it floats sit at 21mm but it seemed like the float had very little travel inside the carb body and was worried it wouldn't close the float needle completely. Does the float needle need to travel very far to close?
Oh and I ran into the stupid bowl O-ring expanding issue, hopefully cleaning and drying them with heat gun will evaporate the gas and shrink them down to fit back in the bowl groove.
Any suggestions would be much appreciated
I hate points ignitions, so my comments have to be seen in the light of the prejudice.
I'd throw the points where they belong in file 13 and fit a DYNA S . Fit and forget, fatter spark, never wears out, better power and fuel consumption, never needs adjusting. Did I tell you how much I hate points? :-)
How bad are your original flaot valves? If they are usable, I'd go back to the OEM Keihn units.
dyna ignition will be a future mod, but for now i can't wait any longer to get it on the road.
Don't think i have the OEM float vavles since i did the carb kits a year ago, might be able to steal them from my other CB350F parts bike.
