CB350F Starter Clutch springs in oil pan. Help!
mikewerx
So I was trying to do this restore as somewhat budget, but when I took the oil pan off, I found 3 springs and 3 posts sitting in there, which I was told was part of the starter clutch, so a couple weeks later, I now have the case cracked open, and I can't see obviously what needs to get done. Looks like a bunch of gears, ha!
So wondering where those springs came from, and how to repair? what order, etc...Thanks!
Those go on the inside of the top piece of that set you have there. The springs go in first, then the caps, then the rollers
See here
http://www.cmsnl.com/honda-cb350ffour-usa_model435/partslist/E++15.html#results
You're going to need new caps and probably springs
Oh awesome, that was going to be my second questions - where to get new ones?!
So how/why did these come out in the first place??? How can I make sure they don't pop out again?
My guess is improper oiling they heat up and once the caps wear through theres not enough pressure to hold them in place and the pop out. But I really can't tell you 100%
Hey Guys,
so i received my new pieces to rebuild the starter clutch, but I can't figure out how to keep the spring compressed in the slot, since there is a hole on the outer edge, and the spring just wants to pop out the other side. Anyone have the anser? Am I missing something???? Thanks!
