Cb360 2 wire tail light into 3 HELP !!
So I took the factory tail light off the bike and ordered a new one on eBay and didn't realized that it only has 2 wires (red and black). I added a ground wire (to the base of the new light) for the new light and attacked it to the bikes ground (green). I either get running or brake light nothing happens when I hit the brake lever.
My question is.. Does the engine have to be running for the brake light to work? Because my bike is not running right now bc there is no fuel (I recently sealed inside of the tank).
Please help
Sounds like you ordered a tail light only. Check and see if the bulb is single or dual filament. Also, the new light grounds through the mounting bolts.
http://www.ebay.com/itm/Custom-Bobber-Chopper-MotorCycle-Brake-Tail-Light-and-License-Plate-Bracket-RS-/180998780093?pt=Motorcycles_Parts_Accessories&hash=item2a245e34bd&vxp=mtr
The light im using is also a 2 wire only. I had to make a small, jumper wire for a ground. The mounting bolts are the ground like Von said. So you could try running a jumper temporarily to battery ground and see if yer light works. Red is most likely brake, and black taillite.
Good luck!
I grounded to the bolt and grounded to the batt. NOTHING lol oh man.. Is it possible that some how the rear brake switch or the 12v rectifier not working properly ??
It is fully charged. I even put the stock light back on and hit the lever and NOTHING. I only getting one .. Either running or brake. Sigh.... : /
Oh man, Solved it ! The rear brake switch was too high up so I tighten it down a little and BAM !
Yeah the switch was too high up (I was messing with haha) and when I lowered it.. The brake light shuts off (running light on). Then I hit the brake lever and brake light turns ON !
Thank you so much you guys for helping. God bless
