nrcb125 Been Around the Block Jan 25, 2013 #1 The bracket for the front looks similar enough. And it just might be dumb enough to work. Anyone done it? Anyone know what the brake rotor diameter is on the 360/400/450?
nrcb125 Been Around the Block Jan 25, 2013 #3 Turnturtle said: The diameter of the CB360 disk is 260 mm. Click to expand... The CB125S's rotor is 240mm. Do you know what the bolt spacing/pattern is on the CB360? Or how far out from the hub the rotor sits?
crazypj Split personality, I fake being smart Jan 26, 2013 #4 Really it would be easier to fit complete front end. The mounting points on 125 forks are not even close to the same as the hydraulic brake mounts
