Cb360 battery size(newbie)
Maverick_86
Hey guys I know this has been covered but I can't find a solid answer in my search. I need to know what battery size I should run in my bike. I'd like to get away with a smaller battery but electrically wise it is all stock. I rewired everything so right now I don't have blinkers but I will be putting them back in. Also the start is the same as stock nothing has changed. I would just like to leave my triangle under the seat empty since I have done a lot of work to clean everything up. I would like one of the batteries from dimecity that is the antigravity one but I. Open to anything. I just don't want to have to pour the acid in myself since I may be turning my battery I. A way that's not vertical. Thanks. Complete newbie here.
Skip Lithium Ion unless you plan to upgrade the charging system.
AGM with a rating of at least 7Ah will be OK.
