CB360 Cafe/Brat MonoShock build
arvoldn
Yet another 360 build!
I have been working on this bike all winter and finally putting up a feed. ;D
Please provide any impute you would like... This is my first 4 stroke build on a vintage bike. only other experience I have was a 88 Yamaha FZR 1000, that I had re-built the Engine on.
I am going for a "Brat" style with mono shock look. I would love to give a shout out too compound cycles with his "Doris" bike build. compound cycles gave me a lot of inspiration in this build, I am trying hard to make this build my own, but its hard when I like his look so much;)
welcome do yourself a favor and get the bike tuned and running and 100% roadworthy,enjoy it for what it is.....
before you ruin it :'(
and a monoshock on a vintage bike is pure madness, such a huge waste of time and effort
Grabbed all my angels for the swing arm off another 360 mono build by a professional...so it should be safe. the only thing that worries me is the strength of the shock, might need to find a smaller one.
arvoldn said:
Getting some Kenda's 110-80/18's this monday ;D
you will need to increase the structural integrity between the swinger pivot and upper shock mount area the loads you have now are totally different and huge compared to what it was stock
also the intersection of the backbone structure and the uprights from the swinger pivot need structural stiffening
you could have at least TRIED to make that garbage you welded on the swinger look more pleasing to the eye :-[,that is some butt ugly haphazard carnival ride lookin' junk bro
too late.
what you need to do is find a shock with the stroke you need to give you the rear wheel travel you desire. then you just spring that shock accordingly and get the valving modified. it looks like you'll need a pretty short shock given how far back your top mount is, but with the cantilever type you often end up around 50% of wheel travel required. a linkage shock is often shorter.
so first mock the bike up and determine your rear wheel travel and end points. then you can measure how long your shock needs to be and go find one. talk to a suspension specialist about what you're doing and what you need and pay them the required amount of money to make it right.
That swing arm angle is CRAZY steep! That'll have a number of issues. Besides raising the back so far you'll have almost 0 trail up front, causing serious instability issues, your chain will be trying to saw through your swing arm pivot and the chain pulling will probably cause weight transfer issues because it is going to do some weird stuff to the squat/anti squat characteristics.
arvoldn said:
Grabbed all my angels for the swing arm off another 360 mono build by a "professional"...so it should be safe.
thats one of the scariest assumptions Ive read on DTT yet. :o
Or am I wrong in assuming that a "professional cb360 monoshock conversion engineer specialist" isnt out there.
for a new shock, you may try davequinnmotorcycles.com . He assembles custom monos.
But its looking cool so keep going. 8)
xb33bsa may not have much knowledge of CB/CJ 250/360 but he is 100% right in this case.
Where you have shock top mounted is the weakest part of frame.
I fit a brace there even on stock bikes, 2"x1" box section, you can hunt through my ' build/blog' for pictures ???
With a mono-shock you will need better (larger diameter/'stronger' forks) You will then find the limitations of the steering head which will also need some work.
In the end it is worthwhile as the improvement in handling is dramatically better.
You will probably want to do 378cc conversion to make use of the better handling 8)
Thanks everyone!
I am new at this, and always learning.
I am taking everyone's feedback and putting it into action, going to re think the top shock mount and get my hands on a pipe bender and re build the swing arm. Now that I have gas in the welder:/
Also going to look into forks and find out exactly how low my swing arm should sit (naked) unless anyone on here knows the angle off hand...?
Thanks again everyone!
-Nick
In an ideal situation, it will be directly aimed at the center of the drive sprocket when the bike is at full sag. That is assuming that the rear axle is centered vertically in the arm. In other words, when the bike is loaded, ie. when it is being driven with steady state conditions with the rider in place so the suspension is nominally loaded, the rear axle, the swing arm pivot, and the drive sprocket center will form a straight line. That is the criteria as far as the chain is concerned. From a deflection standpoint, the rear axle should be at the same elevation or lower than the swingarm pivot at full sag, depending on use.
