fiedler.casey
Active Member
Which side makes contact with the brake pad? The side with a small bevel in the center (oem) or the side with the recessed lip around the perimeter?
I have the original piston on the left in the photos and a replacement piston I ordered on the right. The new one is making clearance issues with the pads-rotor. I believe it's because there's no bevel machined into the back side. I just wanted to check with you all before I contact the company and return their supposed "cb360 caliper piston".
