CB360 Can't find neutral
kief90
Engineering Student
Hey everyone, I could really use some of your expertise.
I am close to finishing my bike and I have nearly everything put back together. I had the engine running fine, but I cannot find neutral. When the bike is not running there are two gears that I can switch in-between, but I haven't tried to change gears while it was running on the center stand. Any ideas on how to fix this? Here are some pictures of the drum stopper plate and the gearshift spindle.
I really appreciate any help because I am flat out stumped.
UPDATE: I was just looking at gear shift spindle (10) and when I move it with the shifter it will move, but the drum stopper cam plate (7) doesn't always move.
Any ideas?
I took another gander at it and I got it into what should be the neutral position, but it is in gear. The gears should not be out of place. The bike has me stumped.
There should be a spring and ball bearing under the bolt on top of transmission.
You may have to remove the clutch to see whats going on, could be a missing/broken pin in shift drum, could be broken hook on shift arm (pivoting piece, #10), could be stopper isn't fitted properly (common) could also be nothing wrong with it, shafts have to be turning for dogs to engage
Take a picture with the clutch basket off (it's bit of a PITA if you don't have peg spanner for oil filter nut)
I checked the ball for the shaft and everything was seated properly. I am in the process of removing the clutch assembly, but I need to order an oil filter nut remover. Once It gets here I will report back with some pictures.
Not sure if this is relevant to you, but the 360 often will not shift unless either the engine or the wheels are moving. It's quite normal to be unable to shift with the engine off and the bike stationary.
It'll go into neutral so long as you're in first or second. If you're in third, for instance, you can't shift to second and so you won't be able to get to neutral.
Have you had the bottom end apart?
Did you put tensioners back in properly (they are backwards on page 1 of your build)
What's up with left side rocker shafts? I've done a lot of CB250/360 motors and never seen any like yours
The oil filter remover tool finally came in and I have had some time between my finals to take a look at it. The first picture shows how it was positioned when I removed the clutch and the ones after show it after I moved it into the neutral positon. Does anything look out of place? Or should I go ahead and start putting it back together and try and run it?
Looks OK, is the 'hook' on the operating arm all there? (looks like it's hidden in picture)
The small spring is intact or arm wouldn't stay up against pins
Does it shift OK is your turning clutch input shaft?
I don't really have anything to contribute, but I can't get my CB360 /out/ of neutral, so I'm interested in the resolution to this issue. Good luck!
