cb360 clutch tension
fredp
Quick question for you guys, how much tension should there be on the clutch control? I've tried adjusting the cable but when i get to the point that the lever feels right the clutch is already engaged. As it sits right now i only have to pull the lever back about a half inch before the clutch is fully engaged. Please go easy on me as i am new to this whole clutch adjusting, i just wanted a point of reference before i jump into using the case adjustment and i might have the "engaged/disengaged" term backwards but hopefully you all know what i mean.
Thanks in advance
Fred
Hmmm... Is it an issue that you only have to pull a 1/2" to disengage the clutch? As long as its working properly, and nothing is so taught that it may cause failure, it seems like thats ok. Just my opinion though. Ive ridden bikes where you need to pull the clutch lever back to the grip, and ones like yours, and Ive always preferd the latter. Makes quick shifts easier. Ill be adjusting the clutch on my 350 to operate like your is now. If thats a bad idea, I hope someone smarter chimes in...
I guess it's just a matter of getting used to it then. Most other bikes i've ridden have needed the lever pulled all the way back. If anyone has any other opinions please let me know.
If the "friction point"..that is when the clutch starts to engage..is about mid point in the lever travel,,,,,good
slacken the cable all the way off and adjust the screw and locknut on the left cover.
'unscrew' it until you have light pressure then turn opposite direction about quarter turn.
Then adjust cable
PJ
The friction zone is a little over 3/4 out and that's what makes me think that it needs to be adjusted.
PJ, thanks for the advice, I'll give it a shot in the morning and hopefully that irons it out.
My 360 was a real pain in the ass to adjust the clutch. if it was set like my 350, when I pulled in the lever there would be a pop and it would not disengage. I had to adjust it "in" a little more than Crazypj suggested. I also noticed some slipping. it some fiddling, but I finally got it.
Just follow the procedure in your manual, what crazypj says. loosen the cable way out, loosen the lock nut, turn the adjusting screw counter clockwise until you just feel tension, back it out 1/4 to 1/2 turn, maybe more. then adjust your cable so it has about 1/2 -1" of play at the end of the lever.
Well i've got it adjusted per suggestions, it's better but not exactly where it should be. It feels like the cable is binding somewhere in the line, when i release the lever it doesn't come all the way out, it almost needs a little help returning.
I guess it's time for a new cable.
A little more fine tuning and i'm fairly confident that i need a new cable/lever combo and i should be good to go.
installed the new lever/cable this morning then adjusted everything and now it's working like a dream. Thanks guys for the help, i'm sure i'm going to have a tons more questions as this project rolls on.
Fred
