jonwright
surfing and motorcycles.... yup
Alright so I am trying to figure out why my clutch does not seem to be working. I have removed the sprocket cover and cleaned and re greased all the ball bearings so when I pull the clutch lever everything works smoothly with in the sprocket cover. However, the rod that goes through the case to push on the pressure plate does not seem to be doing anything at all. The rod goes all the way through and stops but there is no movement. I am guessing i need to pull the right side engine case and check out the clutch assembly but I am not sure what I should be looking for or how to check and see that everything is working. I adjusted my cable so that it should have the clutch totally engaged but it still is not doing anything. Also when the clutch is pulled in.. The sprocket should turn freely like it is in neutral yes? Or am I mistaken?
