i am running handle bars that are not drilled to run the wires inside. is there a best way to run them outside. do most people just drill a hole in the control housing to get the wires outside? thanks in advance for your help.
Yup I had to modify the control housings to get them to fit on my clip ons (cb360). I used a dremel to cut away enough of the housing, on the inside of the lower half. It might take a while to get it just right so that the housings "cinch" up nicely. The left side one is the tricky one because of the wire routing.
