The old signals are running lights and turn signals, and have one wire each for running and signal, and ground through the metal stalk. Your new LED lights are only turn signals, and have a hot and a ground wire. You need to take the red wire and hook it to whatever wire (on the bike) activates your turn signal, and ground the black wire.
Currently you have the running light wire plugged into the LED light, that's why it's on all the time. It goes out when the signal is activated because the running light does not flash. It goes out while the brighter side flashes.
And do not put resistors (or "relays") inline in the wiring to correct the "no flash" or "rapid flash" problem when installing LED signals. The resisitors put off heat, just like a light bulb, and will melt anything close to them. Replace your OEM flasher relay with a digital flasher relay. They're about $10-15 and you'll be much happier in the long run.
