cb360 etc. brake caliper... anyone tried brembo F08 pistons?
overdraft
Coast to Coast
Hi,
Just pulled apart my brake caliper and sure enough my stock chrome plated piston is corroded. I notice that Brembo F08 brakes have 38mm pistons and they're uber hi tech with teflon coating and cheap (Less than $30 a pair and we only need one!). I wondered if anyone else has thought to try using these to rebuild their honda hockey pucks and if they worked or not?
i'm thinkin' they're short, but i'm only going by pictures.... however the only downside of them being shorter would be that you couldn't run the pads right down to the backing plate, which i assume no one does anyway... unless someone is aware of a source of replacement pistons (other than the ebay guy who's got stainless ones for like $80) then i think i might be the guinea pig on this one. or IS there somewhere that you can get replacements for cheap?
does it look like they'd be deep enough to work for a while? http://www.guzzitech.dk/05/05-13/05-13_e.htm
