CB360 - Flat bar and Blue Dot headlight - latest mod
popssss
Active Member
I finally got around to putting on flat bars, they have a slight pull back.
They were 27 1/2 inches across, which made them just as wide as the stock bars, but since they were right behind the speedo, I had a slight issue with the Brake line.
Instead of the brake line running almost straight down, I had to twist the eyebolt so it pointed straight up, then made a direct curve behind the gauges and down.
It was a tight fit.
I did drill the bars, and it took a while to measure it right, and cut. there is a bit more room on the clutch side though, but I think it's pretty good.
I will likely get a new bolt with new steel look brake line.
Has anyone gone straight to the caliper versus that piece on the forks?
Then for the blue dot headlight, it's from Amazon, and the headlight bucket is from Herm and the boys at DCC. It's a high quality piece...way better than the plastic light.
Now for the bracket, get this. I had a KZ 650 headlight bracket, and it was a perfect fit, not a single tweak. it fit into the speedo bolts, and into the single bolt by the for brace.
I did have to hack up the stock bracket to get the parts where the headlights mounted, and the little plastic honda plate mounted ( the one at the lower fork brace....it worked perfectly. It's quite immobile, and I think it's a good height too.
I used Bike master grips to match the paint, and it's close, and bike master bar-end mirrors. So they're not top notch pieces, but they are billet aluminum, and I think they look good. I'm trying to keep the cost low for now, and haven't done the frame, or anything else.
The pipes were rusty, as were the wheels, but fine steel wool, and WD40 took care of 99% of it, and it will get me through this season for sure. I hope to make the rims blue too, and the hubs and spokes nice and shiny.
I'm open to suggestions, since this is my first light twin Honda. I completed a CB550 last year, and the CB 360 is really light, and I thought the 550 was light, and handled well, but not in comparison.
The top two pics are the after shote, the bottom is the before.
Re: Re: CB360 - Flat bar and Blue Dot headlight - latest mod
YogiBear said:
Whatever you do, keep the stock paint! It's such a great color
+1
And the bars look bitchin!
Sent from my DROID RAZR using Tapatalk 2
Thanks guys.
The last couple things will be, wrapping the pipes with either copper, titanium, graphite, or blue pipe wrap...getting a seat cowl to make it look like a single seat, but keep the stock seat...I have another front fender getting replated, doing the side engine covers in silver paint, or polish.
I like the blue too, but may do a repaint to freshen it up...and I'll repaint the Honda and 360T name plates.
It's so original, I don't want to chop it.
Well his is what the titanium wrap looks like.
Let's get this thread into the right spot (it's in the Electrical section). Let me know where you'd like it - looks like a Project to me :)
I'm surprised you had room for the brake reservoir using the drag bars - I wanted them on my CB500 and the fitting fouled the side of the tach, leaving me insufficient room to mount the throttle handle. Did you have this problem? (Maybe the 360 gives more room due to different/smaller gauges or something). Looks great!
EDIT - Nevermind - looked again and see you used the drag-bars' pull-back to clear the gauge. I was trying to use the bend in a DOWNWARDS position, which didn;t leave me enough room. Maybe I'll try that, instead...
