CB360 Fork Oil Weight
overdraft
Coast to Coast
Hi! Putting CB360 forks on my CB350, but I don't really want to buy an entire 360 manual for just the info on the forks... Can anyone tell me the weight and amount of fork oil (from dry) I should be putting in? Thanks!
just got to autozone and buy some honda ATF (tranny fluid) it does the same job. when i did mine i drained all the old gunk out and then flushed it too with new fluid. it will be way easier to put the right amount of fluid into the forks if you use a syringe ( like the ones you can buy to pre-mix 2cyl gas) or a turkey baster
thanks! btw, old pro at the bike shops says atf is around 7w so he's saying 10w fork oil is the closest match. given that i've replace every seal and got upgraded springs i think i'll get 'real' fork oil...
honda reccomends ATF.
Crazy PJ. whos been at it for years, says to put the lightest oil in there; something about how people run high weight oils to compensate for shitty springs.
in 1970, ya... 40 years later, atf has changed... it's no longer generic... do I use Dexron II, Dexron III, Type F, Mercon, Mercon V, Chrysler 7176? Pretty sure in 1970 motor oil was all the same too, but that doesn't mean we can use car motor oil in our bikes anymore... fuel efficiency targets have given us car motor oils so slippery a wet bike clutch won't work... so while I heed the point that a properly reconditioned 1970 fork doesn't need a heavy oil, I'd rather have the latest fork oil technology in the closest weight to prehistoric atf... my thoughts! :)
well i use 15wt fork oil, or a blend of 15 and 10, half and half, you can have great springs, but still nice to have a good fork oil in there, 15w and up will stiffen up the ride a bit depending on your body weight, 10w will be an all around oil id say. just kinda play with it till you find your preference.
incase your wondering.
im 172lbs at 15w fork oil.
i lowered my bike a bit so i like the way it stiffened things up.
Old forks are not the same as modern forks and do tend to need a heavier weight of oil. Modern forks are machined to very tight tolerances and have small oil orifices. Old style forks tend to have larger orifices and can often benefit from heavier oil than modern bikes.
PJ is correct that old bikes often had soft springs and heavier oil was a good way to assist those soft soggy springs. I usually start with a 20 wt oil and move up or down from there. In CB72 and CB160s we use 30 Wt for the track to stiffen things up.
Yo man the manual says ATF 5 bucks at auto zone or you can spend 15 bucks or so at honda for fork oil . I use ATF! the japanese made it to use it so i use it .
Use 10wt
Thicker oil with soft springs is A BAD THING.
It was bad 30+ yrs ago and it's still bad today.
it leads to packing down as fork can't react to a series of bumps.
Damper rod forks are very progressive, the faster you try and move them, the stiffer the damping gets, right up to the point of hydraulic lock up (double the compression speed and you get 4 times the damping)
For track racing it's not a bad thing as it helps prevent excessive dive when braking, on the street, not so good.
Use a 'slippery' full synthetic fork fluid, or cheap out like I do and use 10w/40 full synthetic engine oil
