rockcitycafe
I make things.
had some help from my machinist friend today: bored the outer bearings to 28mm for the needle bearings, bored out the oil galley part of the head casting on the left side to feed oil directly to the center bearing, filed the left and right bearing feeds to keep the oil baths full... you should always have a good machinist friend, the bores for the bearings are so precise the bearings will hold the cam in the head upside down, just pressed by hand into the head... I'm stoked!
