CB360 Help, not charging
djg42
Hello,
Im trying to get my new cb360 running, it starts and idles it wont charge.
The stator is good.
It has a new R/R from the previous owner. Its a CB750 unit.
Im not sure how to test it.
There is a green, red, pink and yellow going into the unit
and a green black and 2 yellow going out. One of those yellows isnt connected to anything.
anytips would be greatly appreciated!
The pink wire is the AC charge coming from the alternator. The yellow comes from the alternator is well and is used for additional power when the high beams are on. Obviously, both of those should be reading as AC voltages when the bike is running. The voltage should increase along with the RPM.
The red wire should be reading DC voltage (between 12 and 14V) and goes directly to the battery.
The green wire is negative/ground. Not sure about the black, don't have that one listed in my wiring diagram and your rectifier looks a lot different than mine...
Thanks alot for your help!
My red wire goes into the R/R, but you said it should go directly to the battery?
The black wire goes into a connection with 2 wires going out, one to the starter solenoid. it is a 3 outlet connector but there is a empty connection like maybe its missing one?
also, this is dangling
More or less. I can't remember exactly but it may take a detour through the fuse box before it gets there.
I assume by R/R you mean a combination Regulator/Rectifier?
If so, then the black wire should go to a connector that splits to a dozen other things including the starter relay, ignition switch, neutral indicator, etc, etc.
As for the loose green, just ground it. Green means ground in Hondaspeak.
thats awesome, thanks alot! i didnt know green was ground.
the black wire from the r/r goes into a 1 into 3 connection-one goes into the starer realy. but one of the connections is empty, is it missing one?
My recco is to do the 5 buck Radio Shack upgrade. Worked like a champ for me. Heck of a lot cheaper than aftermarket and all of the satisfaction of doing it yourself.
Check it out in the $50 mods section.
Doesn't a CB750 have an electro-magnet system and the 360 is permanent magnet?
A 750 would have 3 yellow leads from alternator to Rectifier/Regulator,
Red/white to the main fuse to Solenoid to the battery
Black is rectified 12v
Green is Ground
White (?) from R/R to the field coil which is how they regulate output on those.
Anyone with a SOHC 750 care to chip in and comment?
Green is Ground
CB 500/550/650/750 sohc & dohc all use EMS (slightly different types but still EMS)
There will be at least 2 wires not used on a CB360. (possibly 3?)
You can test in diode position of multi meter but personally I prefer to Ohms test diodes forward and reverse bias.
You already have wiring colours,
Red permanent live, (battery)
Black switched live ('signal' voltage to reg)
Green Ground
Yellow (x3) alternator (pink, yellow, white)
Light green with red tracer is neutral switch
Thanks for the help!
So I think the previous owner put in a new stator and this new CB750 R/R.
This set up didnt work, so he sold it.
So I guess the cb750 wont work on my bike, and Ill replace it.
I checked the wires from the stator for continuity to eachother and to ground and they checked out-Do I also have to check the volts coming from them to verify the stator is good? Thanks again,
DG
750 RR can work, you don't use 'rotor leads.
It will be easier to get 'correct' one though (CB/CM400 is easiest 'solid state' RR to wire in)
I ordered a stock rectifer and regulator, but I dont know how to hook them up as its wired for the combination R/R from the cb750 right now.
The CB750 unit It has a green, yellow, red and pink going in ,
and green, yellow and black going out.
