KrashManhatten
Active Member
heres the deal,
74 honda CB 360, at low RPM it works great, good power and idles until it is out of gas,
how ever when i start to climb the RPM range it will start sputter, and run out of power, the only way to get to speed is to shift gears, the battery is ok, as it runs fine at idle which is the lowest amount of power , and i have the carbs synced.
the idle screw is out about 2.5 turns, ( i dont know what is needed
) and from what i can tell, carbs are about as close as they get. te machine has had no problems with this before, so i am at a loss, and now that my car is stuck in Flordia, and i am in WI little help would be great!
CP
CP
