cb360 ignition switch problem.. I thought.
dp9
Coast to Coast
Ok... where to start. i think my ignition switch if eff'd. in the OFF position, all the connections on the back of it have 12.XX volts. in Position 1 all connections on the back have 0.04 volts. Battery is fine. rectifier was replaced recently with an after market one.
I was riding yesterday, and she died on me. ever since then, this is how the problems go: Bike starts with key in OFF position and Headlight switch (right controls) in OFF position. turn the headlight switch ON and the left cylinder cuts out (no voltage at the coil). Turn the key to the ON position (with headlight switch ON or OFF) and it dies immediately.
She's been runnin for the last couple weeks, poorly though. I thought it was a carb issue, but now im pretty sure the electrical system also needs some attention. SO... do you guys think its just the ignition switch, or an unintentional ground somewhere, or what?
Re: cb360 ignition switch problem.. I think.
Try removing the ignition switch and hot wire it. Bridge the red and black wires on the harness plug with a piece of wire. If it starts and runs fine then your switch needs to be replaced.
after messing with the wiring for a couple hours, the problem is intermittent. i still dont know whats wrong or what i did to half way fix it. i think im just going to throw it in the street and light it on fire.
FUCK I HATE THIS SHIT! anybody have ANY ideas?
i went through all of the chassis wiring, and couldnt find any obvious problem. im in the middle of going through the wiring on the trees, and nothing yet. no open connectors, no carbon marks from arching to ground, nothing.
On my 360 we just hot wired the bike and shes kick start only. The igniton switch was causing so many issues and also was blowing fuses left right and center. Personally I plan on rewiring the whole thing and might (maybe) put back in the switch. Though once you get the hang of it shes not hard to kick.
yeah, mine's already kick-only. I picked up a couple switches today, found a wiring diagram online somewhere for the ignition switch, and I'm just gonna have a key-less bike. one switch for black to red, the other for brown to brown/white. so not safe. I'm also gonna go over all the connections on the bike, like someone on here suggested, with steel wool, and then throw a lil dielectric grease on to make sure there are no intermittent shorts. gonna have to come up with some anti-theft system if this works.
ok, replaced my ign switch with two toggle switches. As soon as I flip the red to black toggle, I lose all power. I cant trace it from the batt with a multimeter, its just gone. batt reads close to 0.0X volts. When I turn the toggle off, the batt reads 12.xx volts (measuring positive terminal to the neg ground on the frame). I threw dielectric grease in all the connectors on the bike.
Does anyone have a method for tracking down an electrical short???
Damn. Looks like you've got a bit of a mess on your hands :(
If it were mine, I'd pull all the wiring, and start from scratch with a bare-bones system to get you started. I had a quick look, but couldn't find any, but I know there's some here somewhere. There's a problem in there, and I have a feeling it will be quicker to start with known quantities.
That's what I'd do anyway?
good luck
ian
Do you know where I can get a new wiring harness? I want to rewire mine as shes got wires coming out of everywhere and theres two massive clusters of wires that scare the crap out of me. I want to reduce all that s***.
If you have a dead short, it should let all the magic smoke out of the wire thats shorting
Your battery is screwed if it drops to zero under load from coils.
Remove battery, connect headlight or similar load and check voltage.
Thanks for all the suggestions guys.
I've now taken the whole turn signal/indicator light system out, and all its associated wiring. My starter has been gone for a while, but now i removed the started solenoid too. aside from the headlight and tail lights, there's no extra wires on this thing. I was really hoping i removed the wiring that was shorting, but no such luck. I got a new battery, which ive already killed. it drained over night on the first night i had it in. the bike ran pretty well that night. really well actually. but the next day it was Back to the same problem of turning the lights on and the bike dying. The batt reads something like 8v while the bike is trying to idle now. Also, now the lights dont work. but they still kill the motor if i turn the switch on. oddly enough, the bike still starts with a kick.
I did find that one of my points was grounding to the points cover, and that there was oil in the points cover because one of the rubber things was missing. So I spaced the cover, and filled in the hole for the rubber thing with RTV black. I also dressed and cleaned the points, which really helped for a little while.
PJ - ive been PRAYING for smoke. at least then i would know where to look. but there isnt any.
any of this tell you guys what i should be looking for or checking? cuz im still lost.
im about to give up on this whole project. anyone want to buy a migraine headache inducing caffeinated 360?
yea let me know where the monster is,
i have similar issues,
it was a tail light wire that found some rubbing somewhere and started grounding. if you really want some smoke, get a set of jumper cables from the car to the bike, bound to make some that way, 500+ cold cranking amps should be able to generate some poof, for good measure, unplug the regulator/rectifyer, and you should be good.
if you need the manual for all the wiring, let me know and i will email you some of the pages out of it, (it is 200meg)
cp
Krash, I read your thread, and I'm thinking i might have charging issues too. bike ran great with a new batt. and reads lower voltage when its running than when its off. I'm going to test the AC and DC voltage tomorrow and I'll go from there. I'll keep you guys posted if (when) things get worse.
when I'm idling its pushing 4.xx volts, but if i unplug the regulator the idle jumps up pretty high and im reading 18-19 volts. Similar to you're prob, Krash. bad part is, my regulator is mounted correctly. Is there a way to test if the regulator is shot?
