CB360, issue is killing me.
Jocassee
So I have this beautiful CB360 that I picked up cheap. It ran OK when I got it but since then seems to have degenerated for some reason.
I have tested all the electictrical which seems to be working fine, I have spark, compression, I just replaced and gapped the points. The left cyclinder has never been an issue, always runs fine.
The problem is the right cyclinder is running WAY too rich. It does fire, but either something is mortally wrong with the air/fuel mixture or timing because when I drive it, and open the throttle up above maybe 5000 it begins to bog down after about 30 seconds and then begins to halt, stutter, and eventually die. It will restart after a couple of minutes with no problem. The Plug is slightly fouled as a result of this behavior but not badly.
If I idle it it will run indefinitely but the right cylinder, again, does not fire quite correctly. I adjusted the air-fuel mixture in and out at all kinds of revs. I do get a slight peak in revs but only very slight and not nearly as much as the left cyclinder which has a very clear peak as I turn the screw out.
Besides the exhaust sounding funny when I put my ear to it (not a regular rhythm), the other external symptom is grey fuel-smoke coming out of the bleeder tube at the bottom-rear of the engine when
The airboxes are off and the carb is clean, however I believe it is a rebuild. Maybe the wrong jets found their way in during the rebuild?
Grey smoke---perhaps the timing is off?
Any and all thoughts welcome...
The slides don't really lift until around 5,000 rpm, it could be a split diaphragm?
Pull the carbs off and check, also the main jets haven't fallen out.
I had the same problem with my CJ360. Turns out at WOT the choke was closing and killing the engine. After zip-tying the choke open (to verify that was, indeed, my problem) I had no further trouble.
I have been keeping an eye on the choke, it is not moving. I will check on the valves as well. Thanks for the ideas so far.
Yeah, check and make sure your setting the timing properly and the your valve lash is properly set. Other then that maybe check for a stuck or bad right on the right side.
