cb360 lower case torque?
Finnigan
Over 1,000 Posts
Just put my lower cases together and after getting all the bolts tight i looked for torque specs but can't find them in the manual...I'm assuming it needs to be a certain spec?
Torque specs are all on one page in an appendix, not in the chapter where case assembly is covered. There are two different bolt sized used on the CB360 cases, so there are two different torques.
The 6 mm bolts are 6.5 to 10.1 ft/lbs. (78 to 121 in/lbs)
The 8 mm bolts are 15.9 to 18.8 ft/lbs (190 to 225 in/lbs)
Do not confuse in/lbs and ft/lbs. This is a common mistake that can cause serious trouble. In other words, if you torque the 6mm bolts to 121 ft/lbs of torque, you are fucked! <G>
In another thread, you mentioned using threadlocker. If you did use threadlocker, then you fucked up already. The threadlocker will be set, and if you re-torque the bolts now, you will break the threadlocker or not get the proper tension on the bolt. You will have to remove all of the bolts, clean the threads on a wire wheel, and start over. When threadlock is used, the final torque must be applied within a few minutes of assembly before the threadlock sets.
I happen to have assembled a set of 360 cases a few days ago, so this question was really easy for me to answer.
I appreciate the insight, I did not end up using threadlocker on the lower cases. As of now the bolts are nice and snug to make sure the yamabond formed a nice seal. Tonight I'll make sure each one is torqued properly in a three stage process like you mentioned.
Hey Alpha, I have to split the cases on my 360 pretty soon as well, so I'm glad to see this info too.
I was wondering 1) if those are "wet" torque numbers and 2) if I should use thread sealant on the bolts like I would use if I was putting something like replacement hex stainless screws into aluminum.
Thanks!
Hey Worst,
I heard that stainless and aluminum suck together so I used the original bolts for the bottom case, they aren't visible anyway so its woryj it to use them and not worry about it. I also bought a replacement stainless bolt for everything on my engine and frame but I'm learning during assembly that I didn't need them all.
I say if they are hidden and still useable, just use the originals no matter how ugly
Thanks!
Torque specs are normally clean, oiled threads.
I always use anti-seize. It's important to remember that when you use anti-seize that the torque it takes to achieve the target tension on the fastener can be reduced by as much as 20%. When using anti-seize, torque to the lower end of the torque spec, not the higher end. If using stainless steel fasteners, anti-seize is mandatory. SS is OK to use with aluminum so long as you use the anti-seize. If you don't use anti-seize, you risk having the SS literally weld to the aluminum, and the next time you remove the fastener, the threads in the aluminum stand a good chance of being fucked.
Yea, I saw it mentioned elsewhere on DTT that stainless and aluminum would cause infinite sadness without something on the threads. I was going to use thread sealant, as I saw it mentioned somewhere else, but hell, I have an industrial sized vat of anti-seize already, so I'll use that! Some lock washers should keep the fasteners from straying too far...
Don't use lock washers. The application does not call for them. The shoulder bolts tightened to the correct tension is all that is required to keep them tight.
Why do I keep referring to bolt tightness as tension?
Think of any fastener as if it is a spring. When you tighten it, it stretches a bit. The goal is to stretch the fastener so that it is in its elasticity range through the expected dimensional/temperature range. Engineers know the tensile strength/elasticity of the fasteners that they use for a particular application. They also know how much torque it take to achieve that tension based on the thread pitch, and the coefficient of friction between the fastener and what it is being screwed into. That's why using anti-seize means you need to use less torque.
Just like how a spring can be stretched out of shape if you stretch it too far, a fastener can be stretched beyond it's elasticity and the result is a fastener that is less tight, not more tight, and it may loosen. (Not to mention that things can strip out in the extreme case.)
There is no vibrational movement between the case fasteners and the cases. If properly tightened, they will not have a tendency to loosen, ever. It's a matter of them being properly engineered to the task to always be under elastic tension. Always clean the threads on a wire wheel, apply anti-seize, and avoid overtightening, and you will never have a problem with fasteners loosening or threads stripping.
Certain applications DO require threadlocker, such as brake rotor bolts and stator mounting screws.
