Swapped coils, same problem. Thought it might've been a ground connection on that side since the ground is through the bolts, and the tab on the aluminum plate that I made to fit the MikesXS coils to the stock 360 bracket broke when I swapped coils. However after fixing it, the problem persisted.
I'm going to pull the hats and check the diaphragms, and email Dyna to see if I can bench test the Ignition Booster.
-MK
-MK
