CB360 - Monoshock Brat
compoundcycles said:
I cut the threaded end of the stock mirror off because is was the only thing I had lying around that would screw into the spot that bolts the brake fluid reservoir down. It was pretty ugly sticking up by itself so I added a compass to it.
That, sir, is ridiculous, and I thoroughly approve!
That compass is so funny it cant help but be COOL. Im telling you...to be a 360 owner you have to posses a slightly off the wall sense of humor.
+1 Many people keep telling me that when i get done building my 360 I will need to find a bigger bike, lol. Why?
Nice bike!
Blocking in where I want lights and turn signals to go. I'm not really diggin the dual mini gages. Anyone want to trade both for a larger single tach or speedo? They're new.
Is that a voltage meter under the bars? If so check this out, it's a little LED indicator that changes color depending on the voltage. Super clean.
http://roadstercycle.com/Motorcycle%20voltage%20monitor.htm
My buddy got one for his Gixxer and it's really slick. I ended up picking one up too, Im gonna ditch the plastic housing and install it in a custom dash or maybe the headlight bucket.
That is pretty slick, but I really want to know what my voltage is. Call me crazy but I'm always curious about how much power its putting out.
Sonreir said:
OK... new design is complete. This one include a digital voltmeter that gives a readout of the current voltage being supplied by your battery or charging system.
http://www.youtube.com/watch?v=zcVMJZEFgbE
And you can charge your phone, too.
Cool! but very big. I like the small volmeter I currently have. Just need to find a good place to stash it.
Still offering the mini gagues for a trade of some kind if anyone is interested.
Instrument dashboard maybe?
I like it. Should pull the gauges closer in behind the headlight. Looks good.
Just read this online and I thought i would share.
"Law of Mechanical Repair - Once your hands become coated in grease your nose will begin to itch and you'll have to pee. "
The tail light I bought came with a license plate bracket. I modified it to hold my turns signals as well under the seat. It's a little crooked at the moment. I'll make the final bends after I mount the rig in place.
I know this sounds like a dumb question. What would be the best bit to do the gauge cutouts? Is your mount aluminum? I have a nice sheet of Stainless and would like to do something similar but am limited on certain tool availability.
Thanks,
Gary
Use a hole saw with a cordless drill, normal drill will spin too fast and burn teeth off
Don't buy the real cheap multi blade type, they don't work on metal
You really want a carbide hole saw for stainless, but they don't come cheap.
What ever type of hole saw you use on stainless, spray liberal amounts of WD-40 on the blade/surface.
This helps keep the teeth cool, and aids in getting the removed material out of the way.
1 inch depth...
http://www.amazon.com/dp/B0056CDF7M/ref=biss_dp_sa1
3/16 inch depth...
http://www.amazon.com/Jancy-Slugger-Carbide-Tipped-Uncoated-Diameter/dp/B004S2LWHQ/ref=sr_1_1?s=industrial&ie=UTF8&qid=1365504453&sr=1-1&keywords=Jancy+Slugger+Carbide-Tipped+Annular+Cutter%2C+Uncoated+%28Bright%29+Finish%2C+1%2F2%22+Shank+with+Flats%2C+3%2F16+Depth
http://anchorlube.com/anchorlube.html
I cut a lot of holes in stainless w the 18v Dewalt drill. They are a bit pricey.
Jancy Slugger Carbide hole saws are the best for cutting holes in stainless. Anchorlube is available from fasteners inc. its the best cutting fluid.
