CB360 - Monoshock Brat
That is the tool for cable lube. Worth the money 10 times over IMO.
The cheapest, most useful item in the toolbox!
If you don't have one you must be a masochist, any other method is an absolute pain or you have high-friction cables with shortened life.
Crazy
The only problem is trying to find those damn straws for between the can and tool
compoundcycles said:
The cable coming out of the throttle does a big loop downward. Its a much smoother curve than I actually drew. Thanks for the suggestion. Ill try getting some chain lube to spray to down the cable.
Even so, it will be a smoother sweep down the left side.
Every bike I've ever worked on with a 'right side' throttle cable has had problems, even when it's a factory fitting with multiple guides and stays
No way man, carb cleaner and brake cleaner both have them, I've got several laying around! ;) Go get some cleaner and get to it!
Every time I buy a can I forget to look if it has one and every time some one has taken it off. Ohh well, teach me for not checking.
WD40 cans in Oz now have the option of a built in one so you never lose it:
Greatest invention ever!
Too right mate!
Love the stuff - and it comes in 44 gal drums too!
(but no straw for the drum).
Started tuning the bike today. Many frustrations.
1) I can't start the bike in any idle screw or cable adjust configuration without also opening the throttle manually. Once it's started it seems to idle OK.
2) When I lean the bike to the left it revs higher, when I lean the bike to the right it idles so low it dies.
3) Also, I rebuilt the starter with a suggested starter rebuild kit, still wont turn the engine fast enough to fire up. It's the same as before. I'm all kickstart now.
Anyone else running VM30's? I'd love to see a picture of how you're running your fuel lines from the petcock to the carb inlet.
Double posting this in case it got lost on the previous page. Started tuning the bike today. Many frustrations.
Number 2 sounds like cable routing maybe. Or did the original carbs have a fuel pump?
Have you checked your spark plugs to see if they are wet, or what color they may be? Opening the throttle allows for a lot more air...so you may be running far too rich on that idles circuit. Another thing is to verify float levels as this can cause an issue for question #2 (see what I wrote below though too) I had a similar problem with the KZ550 when I was going through it's carb settings.
When you say LEAN, do you mean that you are sitting on the bike and "lean" it over as if it were in a turn? Or do you mean, "I turned the handlebars to the left and right"
With the starter, make sure the power line to it is very SECURELY attached on both ends. But kickstarting is cool anyways right? ;)
I will check the plugs. What should I be checking with the float levels? Making sure they're set evenly? This is the vm30 kit from DCC that is "pre-Jetted" for cb360's. I was hoping i wouldn't have to adjust much at all.
LEAN as in, front tires stays straight and I simply lean the bike to the left and right. So that probably rules out a throttle issue as no cable positions are changing.
This is the Setup from DCC website: 150 main jet, 3.0 slide, PO needle jet, 2.0 air, 50 pilot, and 6F4 needle
Thanks for the help, please keep it coming!
As far as the starter goes I'm pretty sure all the connections are good but I will double check.
Pre-set is not always perfect, so double check the floats just to see if there is any noticeable discrepancies. Otherwise, I bet they are not in sync at all either, do you have a way to check that? (manometer etc?)
Good to know the cable routing isn't the issue, unless it's sticking, just make sure both slides shut nicely and slide smoothly too. Hope you find that it's something really simple! And just to double check, you have set your valves etc already correct?
I dont have a manometer. Is there a set of vacuum gagues that can plug into mikuni vacuum ports? Actully I dont even k ow where on the carb body the vaccum port is. Ill check the valve clearances tonight.
