scottyhypnotic
I had carb issues, and from all the starting and cranking the throttle I think I may have flooded everything and ruined my spark plugs... attached is a pic of them. All black and gross. After a bit it just plain wouldn't fire. Starter was going, but nothing.
I removed, cleaned, and re-built my carbs, and replaced the spark plugs. Put everything back together.
But when I try to start up the bike the same thing is happening. Basically nothing. Lights are on, starter motor is going, engine is turning a little bit, but nothing.
Any ideas what could be going on? I thought maybe I flooded the engine or something, so I turned off the gas, removed the plugs, and pumped the kickstarter a dozen times, because I heard that can help things? But no dice.
I should mention too that I have a Pamco ignition. And the battery was freshly charged. I do notice that the headlight doesn't seem to be coming on now.... all other lights and horn do.
