CB360....Piston question...
Winks
Hey
Well I had a slight mishap with my cb360, the idler gear snapped in 2 pieces and luckily dropped to the bottom of the engine. Now as many of you know this means I had no oil....thats right, burned my cam, my head, melted the cam guides(and as you 360 guys know you can't find replacements), and scored my cylinder walls. So its time for a rebuild. I was lucky that I had a parts bike with a good cam and head, and a set of mediocre cam guides. I was considering since I have to rebuild anyways, it may be time to overbore my cylinders, any opinions on this?
Now if its a good idea does anyone have a hook-up or know of a good set of pistons and rings to use?
Now as a side note if anyone has a set of cam-guides they want to sell I would be appreciative.
Thanks
I am in the middle of a CB360 engine rebuild myself, and I can back you up with the scarcity of parts. It took me about 2 months of scavenging eBay to find a decent used cam guide. I have seen oversize pistons and rings on eBay, and I was lucky to score a piston rebuild set (pistons, rings, clips, shafts(?)) for stock bore for not a lot of $$$.
best of luck!
The gear I am talking about is a stepped down gear where one side touches the centrifugal oil filter, and the smaller side drives the oil pump. The gear must have gotten locked causing a large section to drop off into the oil pan. I should have taken pictures of the head and cams because it was a mess.
I was thinking of doing a 1.00 over sized piston, but I would like to hear more about your 378cc 'kits'.
