CB360 Project
hanly2
OK so I have been lurking for quite some time and I am finally starting some work on my bike and wanted to post so that I can get some help and input when needed. I have this bike that I got in June or something and I am going to cafe it on my tight budget. So far I stripped the whole frame and I am trying to figure out where I want to mount the battery box. I also need to cut the frame and get it ready for paint. Here is some pics of what it looks like and where I was contemplating mounting the battery. Is there any reason I can't mount it in this location? I plan on making the bottom flush by cutting off all the brackets and mounting it flush with the bottom of the frame but in that location.
I think it mostly depends on what you are going to do with the tail section and if you are going to lower the rear suspension. You might want to look for a battery with the dimensions that will fit your plans for your seat/tailsection. Also, you might be able to get a AGM sealed battery.
What year is that? Looks like I have the same blue tank on my '74 CB360.
I got some work done on the bike today I started sandblasting the frame but my tip on the blaster was worn out and it stopped siphoning real good so I had to order 2 new tips so that put a big damper on that process. So I sanded and painted the front wheel black and then I wiped the paint off of the lip so now it is all black but with a brushed lip it looks pretty good. I also mocked up a picture of the finished bike. I am not sure I like the color scheme that much now. I am actually thinking about painting the wheels white. What do you think?
how was painting your wheels? was it a huge pain getting in between all the spokes?
i say keep the wheels black and/or green spokes
but getting a paint that will accept the flex and strain that spokes take is a problem! allot harder than it looks... i woudl try and epoxy based paint if you are not going to mix and shoot them... you need flex added and hardener if you do mix and shoot
That is very good advice. I also will remind everyone not to try this at home I am a trained professional and I am just trying to get the bike done without spending to much time or money then when the time comes down the road if the paint peels I will do it right the second time ;D But if I was going to do it right the first time I would definitely look into using some bulldog flex additive or something. If you want to really know how to build a bike read Joe's thread. Mine is for amusement purposes only. Thanks
Dave
ahhh by no means man! if you rock white... rustoleum appliance epoxy white is JUST killer and tough as nailes! give it a go
Ok I tried to make some progress today. I sandblasted the upper tree and started to sandblast the swing arm. An hour later and hardly anything was done. This sand blaster is a real piece of crap but it's all I can afford. I was going to just leave the aluminum parts brushed but I think it's too much work so now I am just going to paint them all black can I just spray right on the metal? I'm not sure what everyone else has been doing to prep the aluminum parts.
han, hit them with a wire wheel first, i have a harbor freight blaster, crap as well, but i will loosen up any old paint with some air craft stripper then wire wheel, or just blast... makes life so so much easier!
yeah did that part, but now do you just wipe the part down with thinner and spray it with paint. I tried to do the bottom tree a few times but the paint was just fish eying like crap maybe it's too cold?
i NEVER use thinner, i use denatured alchohole, PREP, or after the item is painted i use mineral spirits as it will not harm the paint...
Whenever I shoot metal I use an etch primer first:
The "Specialized" one on the left
Mar-Hyde... or however you spell it makes one too, but it seems to clog my gun up really bad
You can get either in aerosol too.
Fish-eye is a result of the presence of silica or silicon (as in the ingredients of some blasting media). It can be imbedded as a result of the blasting process. It is also in some sandpapers. If you are using rattle can, you have to clean super well, including some abrasive, such as a soft brass brush. Then wipe down with alcohol or acetone. Mineral spirits leaves a residue that is not perceptible but still there. A final wipe with a tack cloth and then paint. (i used to be a professional furniture restorer, not exactly the same but the guiding principal is the same: prep is everything) Btw, when I just did my frame, I had fish-eye because I ignored my own advise, lol. Good luck and I'm sure it's gonna be a great build.
So I picked up a new tank today from Tex at caferacer.net. And I had to put my bike back together as I didn't like the way I was doing things. I need to mock everything up first before stripping and painting. So I took some pics of the new set up and the old one. I really love the new tank, but I am having a problem with the petcock hitting the carbs. Not sure if I can add a brass extension on it or something to make it work I would even consider a ball valve just to get it to work. I will need to cut the stock tank mounting location and move it back a few inches and re weld it but I think that shouldn't be too hard. Here is some pics let me know what you think, I need all the help I can get.
Almost makes it just needs to be like 1/2 inch lower
Stock tank
New tank, it will be lower in the rear but it's sitting on the seat right now.
Riding position, if I can make rearsets like Troy did.
Shot from behind with the new tank looks so much better.
Man that tank looks great on there! I sure hope you can use it. I'm sure someone has ran into the same problem. Hopefully they will chime in. Until then, what would happen if you raised the whole thing up an inch or so? Looks like it may clear and might even help match the height of the tail. If you did that it also looks like the seat would hide the tunnel on the tank once it gets padding. Just a thought. Troy
Great thread. I am currently working on a '75 CB360 with a CB500T tank. I do not have the carbs mounted so I didn't know about the interference issue. I really like the CB500T tank on the CB360. ;D I am thinking about doing a rear fuel tank with the battery and electrics under the CB500T shell. That might be a bit beyond my abilities right know, but that is what I'm kicking around.
Good luck with your project.
