CB360 Project
I will. I just swapped front ends for a CB350F today and I will probably cut the front mounts to fit the CB500T tank sometime tomorrow. Then I can see what is happening. I am trying to get a good set of carbs going. I have a bunch of spares, but I am 1 or 2 pieces short for each type >:(. The 360 carbs have a bad diapram and right side body. The early model 350 carbs have a bad float and I can't find one, and I am missing a float bowl on the later model 350s. The 350 carbs have a slightly smaller diaphram cover. I don't know if it would be enough to clear the petcock though. I'll try the bodies on when I get the tank mounted.
ok so a buddy of mine came over yesterday to see the bike and we just started doing some work. I took the old rear section of the frame that used to hold the fender and taillight, and trimmed it and welded it back on. We are not the best welders but we sure did get lots of practice with a grinder. ;D I ran out of wire and still need to build up the transition from the larger diameter pipe to the smaller but it looks pretty good and I was able to kill 2 birds with one stone because now I have my turn signal mounting tabs back. We also resolved the issue with the cb500 tank. I was able to bend the bung in the bottom of the tank so that the petcock will clear the carbs and it sits at a nice angle to operate and run the fuel lines. I then drilled out the bolt where the front of the battery box used to mount and I am going to weld some all thread to the mounting tab at the back of the tank that will run straight into the hole and I will secure it with a wing nut from the bottom. It will be real easy to get to without the side covers and with pods for air filters.
Ok so I ended up breaking that rear section off. When I got my seat all cut out of the mold it didn't sit right on the rear loop. So I went to Home depot today and bought some 1/2" and 3/4 pipe. Then the guy at the store told me that I would not be able to weld the pipe on my frame because it wasn't chromoly. Is that true, do I need to go buy some chromoly pipe for my back half of the frame?
What kind of pipe did you buy? The guy has no idea what he is talking about regardless, because you can weld alot of other stuff besides chromoly. If I had to guess it might be gas pipe that you bought which is mild steel. If it is gas pipe (or galvinized water pipe) you can weld it? How are you planning on bending it?
A photo would help. Troy
It's black pipe from the plumbing section, he said something about carbon steel or something like that. I only have a small mig welder, but I'll give it a shot anyway. I don't know how I'm going to bend it yet, I might just cut it on angles and have it come to a point in the rear instead of a curve?
Not sure I follow you. Did you break the seat or the frame/loop? Did the loop come up and hit the seat and you decided to remove it???
I believe the frame starts at an upwards angle just before the shocks. The loop just continues this angle. Are you planning on changing this angle? is there any way to use the factory loop? It might be way easier than trying to make a new loop. Maybe more photos whould help.
someone selling FZR rear sets for $50 here http://www.caferacer.net/forum.html
I'll check out those FZR ones thanks. I had the factory loop welded on as you can see in the pics but the seat didn't clear it because it was too wide toward the back. So I cut it back off and now I am starting over with new pipe.
Could I use a shifter like this with a bicycle peg and a bolt? If so I could just buy 2 shifter pegs and flip one over for the brake.
http://cgi.ebay.com/ebaymotors/GSXR-600-750-1000-1100-GEAR-SHIFT-SHIFTER-LEVER_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1163Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem370154222060QQitemZ370154222060QQptZMotorcyclesQ5fPartsQ5fAccessories
Ok so I took the trash out tonite and made a pit stop in the garage 2 hours later this is what I got done.
Mocked up my new headlight brackets and turn signals to see how they looked. I love it!!
Put my new handlebars on and I am not too sure about these. I think they may be too long or something, but they are only 28".
Also installed my new taillight onto my seat.
And here is a pic of my electronics pan and you can also see how I mounted the cb500 tank for the other guys that were using the same one.
The shaft on that shifter looks larger than 3/8" which if I remember is the size of the BMX bicycle pegs. You would have to purchase/make a sleeve/bushing to fit over the mounting bolt and inside the shifter hole. You also have to be able to tighten down the BMX peg. You cant tighten it against the shifter, because the shifter would be too tight to work. All these problems can be worked out. It's all part of the problem solving process.
Another solution: You could make your own pivot point for the shifter, thus making the shifter pivot seperate. Very, Very easy to do. Just weld the right size bolt where you want it. a couple of brass/teflon washers and a lock nut and your mounted. Then just figure the linkage. If you decide to change it in the future, just cut off the bolt and you are back to square one. Its just a matter of what you want to put into it. All part of custom fab. and part of the problem solving process.
Another solution: You would have around $31.00 in the shifter above before purchasing pegs. You could spend another $13-$15 and buy this for $33 plus $12 shipping. http://cgi.ebay.com/ebaymotors/2005-SUZUKI-KATANA-GSX-750F-LEFT-REARSET-REAR-SET-OEM_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1171Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem370153829954QQitemZ370153829954QQptZMotorcyclesQ5fPartsQ5fAccessories
It has the peg with it. However you would still have to mount it. But that would be very very easy to do.
As far as using that shifter as a brake lever I'm unsure of it's strength. If you have mechanical brakes you want something strong. Maybe someone else can chime in with an opinion. But on the shifter side, it all depends on which route you want to take. Good luck
Troy
How did you tighten the peg down on your set up? How does the peg tighten up on this set up without keeping the lever from moving. I would like to buy this set up and just ditch the bracket part and just use the peg and the lever
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=290292507399
That tail light kicks ass. I like it alot! Looks like the tail could be trimmed some (Just my opinion. Remember when it comes to looks, its just like art and what makes you happy) :). Do you have any photos from the side?
I do need to trim the tail still it's really hard to draw the shape that I need on it. I have been gradually shaping it with a angle grinder. I will take another pic tommorow from the side but there is some earlier in the thread before I cut it out of the rest of the mold.
I never got to that point. I thought about making a sleeve for the shifter to pivot on and the peg would tighten against that. The other thing it seemed that it would be much stronger to weld the bolt on the back side of the hole on the frame.
If you are set on using the same pivot point as the peg mount you could put a bolt (grade8) through the hole It would have to be threaded perfect to allow space for the shifter (no threads) to pivot. Then be threaded where the peg could tighten down. Kind of confusing the way I explain but the bolt would not have threads all the way up. There would be room for the shifter to pivot. You still would have to work out the problem with the shaft size differences. The bolt would have to be welded to the frame.
Another solution would be to sandwich the shifter between two washers and weld them in place to create a space for the shifter to pivot. Again, shaft size difference would have to be addressed.
There are always ways to get things done. You just have to work it out. Sorry I never got to this point because I never thought of it as a big deal. Just put your mind to it and get in there and tinker around. You'll figure it out. Troy
hanly2 said:
I figured just use a bushing with a washer on the end or ends whatever works.
Bushing and couple of washers could work. The bushing would have to be the correct width and diameter. It would have to allow room for the shifter to work but be tight enough not to feel loose. It would also have to be teh correct ID and OD to properly fit the bolt diameter and the shifter diameter. The correct id and od bushing could be a little hard to track down because you are talking about some pretty tight tollerances. Any slop and the thing will feel very loose. Don't let me discourage you. Keep your head up. I know you'll get it. It will just take some thinking and tinkering. Troy
I got some stuff done in the past few days but I can't find my camera so we'll skip that for now. Today I thought would be a good day to start work on the motor. I had 2 oil leaks that I needed to seal and that is the only reason I was going to dissassemble it. 1. Was the leak where the tach goes into the head. 2. was the leak of oil that kept getting into the points area. So I took the head cover off and found out that that was all I needed to do to get to both of these seals. But I cannot get the tach gear to come out, I took off the c clip but it still doesn't slide out is there something I need to do? I also found the 2 seals I need on Bike bandit.com. Also found out that my rear tire on my bike is really a cheng shin hi max front tire. It is 90/90-18 So I figured I would order a 110/90 and put it on the rear and move that one to the front. Do I need to buy a new tube for this tire or use the one thats in there now? Let me know I would like to place the order soon.
Thanks
Ok I painted the frame the other day. I could only find one can of paint at the 3 stores I went too so I need to find another can and scuff the frame with some 400 or so and put another coat on it. Then I think I will wet sand it with 1000 and put a clear on it to make it shine more. I used duplicolor metal specks paint. You can't see it real good in the pics but it looks bad ass in the sunlight. I am also waiting for my oil seals to come from bikebandit then I can put the motor together and paint that some color.
close up of paint
whole frame
Battery box area
