CB360 Project
Ok the weather was nice this weekend so I got some work done, but that just creates more problems and questions so I will show you some pics first and then ask the questions, Deal?
etching primer
Engine and side covers with new bolts.
close up
close up of frame cleared now
Inside of right side cover with oil thingy.
I wish these bolts came with a list, I have all these extras and I don't know where they go I guess some go in the head cover but some look like the head on them will be too small.
Ok now for the questions,
1. I sand blasted my side covers and now I got some sand in that thing on the right side one, I can feel the sand when I push on it, it is spring loaded. Can I take it out and clean it?
2. Should I leave the points cover black or make it match the side covers? (just a simple opinion question you don't have to think about this one)
3.Before I put these side covers on for good, I was wondering if there is something I should put on the gaskets so that they don't stick to the motor in case I have to remove the covers later.
4. I still can't figure out how to get the gas cap off, it doesn't seem to have any c clips just a pin going through it that looks like it was spread out on the one end to hold it in.
5. Does anyone know if a 100/90 tire will fit with the front fender.
That does it, Thanks for the help in advance.
Peace,
Dave
Got some work done today my bike is now a roller. I just am having the hardest time getting this seat to look the way I want, I just keep cutting and cutting it. It's hard to make both sides even. But at least I'm getting closer.
The colors are definitely interesting, but green isn't my cup of tea.
I'm also wondering the same thing if 100/90 will fit the front fender. Anyone?
Ok I got a lot of work done lately, I mounted my tires and painted the wheels a nice semi-flat black. Also got the seat and the tank painted with the first go around of epoxy paint, the only problem is I wet sanded the shit out of that tank and did not see any problems on it but after painting it there is a ton of pinholes in the filler and I also found a dent that I missed. What do you think I should I hit it with 80 grit and take it back to metal where the dent is and try to blend it in to the rest of the tank and sand the rest with 400 and use some heavy bodied primer to fill in the pin holes. Man I just hate having to wait a week for the paint to cure it really slows down my progress. How long should I wait before I sand it in this case. Joe I need to know your epoxy paint rules, I can't find the procedure you posted.
Thanks
Dave
Man I wish I had your tires ;D anway, that epoxy sands super hard. You'll be forever trying to get every speck back to bare. I did this process many times :(. I tried to do just what your saying but quickly switched to paint stripper and tried to be real careful not to gouge the bondo. You'll still have to redo some body work but I tried just the sand part and it is way harder than just starting over. If you do decide to try sanding it back to bare you may want to wait a couple of days otherwise the epoxy will fill many sheets of sand paper.
The way I did mine was after all the body work and sanding completed I prepped the crap out of it first. My final wipe down was with mineral spirits. Now time to primer. Hit it with self etching primer for about 3-4 coats, then let that set up. Lightly wet sand with 400 then hit it with many coats of heavy filling primer. Let that set up. Wet sand with 400 and prep it for paint. Each time I wet sanded I washed with dish liquid, let it dry, then wiped it down a few times with mineral spirits. Not sure how everyone else does it, but thats how I did it. Keep in mind that each coat of epoxy has to be completed within 1/2 hour (the can may say 1 hour but I'm not sure, I wouldn't want to chance it) or else you will have to wait atleast a week. I tried to rush it once (it was about 3-4 days old and it wet sanded like it was cured) but it still it f' up. Hope this helps. Troy
you get a 1/2 window to shoot this paint, after that you need to wait a week to re shoot... on the body work that needs to be done, how big is the dent can you use a glazing compound to cover it? the pin holes are from not using a primer... if you do body work on the item i do sugest using a self etchign prime as the bondo will want to out gas and primer will catch that up... sanding it is a pain! i use 1500 - 2000 wet sand with a touch of soap in the bucket and then wipe down with denatured alchole for other coats...
