Cb360 Starter Removal
fiedler.casey
Active Member
Going kick only. Pulled the starter, starter sprocket, and chain. Do I need to remove the other sprocket or am I done here? See picture.
Not just the sprocket, but the clutch should be removed too. The Clutch never spins at Engine RPM when connected. Unconnected, it will probably come apart.
You need to pull the rotor to removed it.
