thrillseeker
Freshly rebuilt 378cc 360 with new harness is very hard to get running. Need help!
When it does start running I have to keep the throttle fully open or it stalls. It never gets above idle rpm range. Noticed some fuel splashing out the back of the carbs when it's running as well. So I thought it was rich but when I kicked it a few times with ignition off the spark plugs seem dry. Battery is strong. Timing is good. Spark is strong. Compression good. Valves adjusted. Timing chain tight. Carbs rebuilt by pj. I also checked the temp of the headers after running for a minute and they were dead equal so it doesn't seem like a problem only on one side or the other.
I think I'm going to double check the timing and valves to make sure I didn't screw something up. I also took the carbs apart and cleaned them well since it was 9 months or so ago when pj worked on them.
Help is greatly appreciated.
Update:
Checked cam timing and ignition timing. Both set and it's still not running.
Update:
It's definitely a fueling issue. Spark plugs are dry after a few kicks. But float bowls are filling up and fuel valve seems to be working.
Update:
Update:
said:
