Finnigan
Over 1,000 Posts
I'm following the manual best as I can and I'm testing the continuity of my stator. I seem to be passing all the tests I should be failing and vice versa, I know these stators don't burn out easily so if someone has done this before I'd love some input.
Got a DMM and I'm testing between 4 pins (yellow, pink, white, and green with pink striped wire)
There is continuity between yellow/pink, pink/white, yellow/white
The green wire with pink stripe has no continuity with any of the others but according to the manual it should be the other way around?
