CB360 stator voltage readings, help please.
trek97
No Custom Title
DTT BOTM WINNER
I got a battery charging issue.
Stator unplugged.
I read continuity through all three leads.
pink-yellow
yellow-white
white-pink
none read to stator housing ring or ground.
with bike running...
18vac on one pair
20vac on next pair
ONLY 3.5vac on next pair
also read each lead to ground (bike running)
8vac
8vac
2vac
whats up with that?
also I havent yet checked the rectifier. doing that next,
Just a thought, I had the same issue that I caused myself because I had mixed up the plugs that go to the rectifier and the stator, they are the same connector on my bike and when swapped the bike will not charge. I was changing out rectifier and regulator for a combined unit, and didn't pay attention when I unplugged a few things. ::)
Your numbers are good on the stator, there are only 2 windings, and you won't get much voltage from lead to ground. Pink to yellow, pink to white should make better than 12-15 volts at idle, and better than 30 volts at say 3500 rpm.
and the frogman saves the day...again!
thanks dude, after looking at the prints. I saw the one has 4 windings, the other 2 and the last would be the ground...I was really beginning to sweat that.
after checking the rectifier this morning I believe that mine took a shit. And the stator was the only thing I unplugged when I did the engine. so Im good on the plug.
You dont have a spare rectifier laying around do ya?
Don't buy another stock rectifier. They will fail, they overheat and take a dump. Do yourself a favor, spend $10 on Ebay and grab a nighthawk 250 combo unit off of Ebay and never worry about it again. They are solid state and last forever.
Amen to that Kiley, mine had a termial that was rotten right at the unit that cause all kinds hell, found it one day on accident when I touched it and it broke off. ;D
I went changed out my rec/reg with a combined unit out of a Kolher engined lawn tractor.
http://www.ebay.com/itm/REGULATOR-RECTIFIER-KOHLER-25-403-03-25-755-03-R8969-/200647323471?pt=LH_DefaultDomain_0&hash=item2eb7832f4f
Search the part number on that listing, should be able to get it locally, cept john deere charges out the ass for them.
Then you take OUT the regulator toss it and tape up the wires for it since you won't been needing them. CUT the wires off the rectifier and use them on the new unit, it will mount pretty much right in the place of the regulator. Unit is slightly longer than the regulator but about 1/2" shorter.
I've got 100+ miles on my 360 since I did it and its working fine, charges evenly now, right at 14v.
just to keep things fast and simple I ordered this,
http://www.ebay.com/itm/221097426897?item=221097426897&viewitem=&sspagename=ADME:L:OU:US:3160&vxp=mtr
I just dont want to dig into wiring at this time. hunting is approaching too quick. and I would like this thing running for barber. This winter maybe I will re-wire the old girl.
Also guys...
with everything off. battery terminals at 12.5 vdc
idling I got 11.5 at terminals
5000 rpm I got 12.9
CRAP. New rectifier came in today
No change.
w voltage regulator unplugged I only got 12.5 vdc at idle and 13.5 volts revving high at battery terminals.
w voltage reg plugged in I got 12.25vdc at idle and 13 volts high revs.
The stator continuity test is right in line w manual. I removed it very carefully during rebuild, wrapped it in a rag and set it on shelf.
got to be the rotor...thats the only thing I messed w. I wasnt rough w it at all. tried to loosen bolt. couldnt keep it from spinning. so I left it on. (before I learned the penny trick) the starter chain and a wrench stuck to it a couple times. Maybe thats all it takes to get the magnetism out of whack. Maybe it just barely had enough to start with. I dont know...got one coming from ebay. Hope its good!
By some miracle of the Honda gods. The ebay rotor arrived. I made the swap. And I think this has done it.
with everything hooked up as it should be I have12.3 @ idle and 13.5 vdc across battery terms @ 5000 rpms!
I was desperate for some alternative test ideas so I turned to the crappy climber manual.
It says "a sharp blow, a strong magnetic force or OLD AGE" can all cause a rotor to fail.
I think just messing w it during rebuild was enough to kill mine. I think its just barely weak enough it just wont do its thing.
Charging system on 360s suck, regardless of how new they are. ;D I'm gonna be in the garage tomorrow I'll take some pics and vids maybe and doo a good test session on mine. If I can, might be to busy messing with the 450 and the beers. ;)
I bought my CB360 in 1978. It pretty much went through a battery a year. I finally put an off/on switch on the high beam. this way, I ride with low beam on, and at stops in traffic, switch on the handlebar to high beam (no headlight on). That allowed the batteries to last 2 years.
Between the marginal alternator (130 watt on a good day) and the vibration on the battery, it just is a real pain in the buttocks.
hmmm maybe its time I look into a led headlight. Since I nailed the raccoon I dont ride in the dark anyway. So its only got to be functional for others to see me...not useable by me.
Dunno why I have such good luck with electrical systems?
I get steady 17v at 1500rpm (regulator disconnected) and 14.2v with reg/rect combined unit
Nothing wrong with MODIFIED 360 system
