nismoman8899
Active Member
Ive posted around a few times got some great answers with alot of help, going to jeep this my main thread from now on. Been messing with my 76 cb360, has a cl360 engine in it when i got it. Hasnt ran in a long time last titled was in the 80's redid the carbs the electrics started solenoid tires brakes set timing all the good stuff. Hickups here and there, nothing time didnt fix.
So everytime i run it. Let the bowls empty with engine running. Few days later. I find the oil has a gas smell. So i drain it for a few days run clean oil through . Drain again just to get the gas out.happend about 3 times in the length of my owner ship.
Had a small leak in the head gasket. Not hi ing mayjor. Figured mine aswell change the gaskets. All the good stuff. Well lastnight didnt end well, pulled the points and associated parts off pull the cover off. Found the cam has been digging into the cover rocker arms have some decent wear. Kept going. Pulled the head off found even more damage pulled the jugs off. One slipper is broke in 2 peices. (Front) took thebrear out shows decent wear. Never had any noise at anytime. So now im down to pistons and case in bike. Any ideas where i should go from here? Attaching pictures of everything. Any help and or suggestions would greatful
