CB360 throttle problems.
Kain
Hey everyone. Having a problem with the throttle on my CB360. It's not springing back. The bike is at the mechanics now and I'm desperately trying to safety it so I can actually ride the GD thing. this is the only problem that's left then I'll be legal!
The only thing is he says none of his suppliers list throttle cables for the 73 CB360T!!! I don't know anything about the setup so what are the specs that would be compatible with my bike?
Thanks for any help you can give!
Only thing I can say is to try and find one at either a salvage shop or Ebay. I don't think honda supports that anymore.
I got the one I was missing from e-bay.
Either that or adding a spring as a return ( i did this initially, and it seemed to work. Either that or it's binding. Does it come back if you push on it lightly?
Check to make sure that:
A. Your housing is tightened down cockeyed on the throttle tube
B. That your grip isn't pushed too tightly up against the switch housing.
C. Your cables are fully lubed and adjusted correctly.
i was doing some work on my 360 and found that the push cable was rusted. i actually snapped it while trying to lube it. i have a return spring at the carb end of the throttle. so ive just been running the one cable throttle(pull). i would say lube your cables and see if there is a return spring at the carb end. if there is a spring you can lose the push cable until you find a replacement. it should only be a matter of measuring how long the cable part is and putting a new one in the old sleeve. so long as the sleeve isnt ruined.
good luck
It comes back slightly when it is fully twisted (that's all I really saw at the shop, as I said I don't actually have access to the bike cause It's still at the mechanics). This is after the mechanic lubed up under the grip a bit. He said he'd try to open up the throttle box and lube it too but he couldn't undo one of the screws while I was there (it was stuck pretty good).
Also can someone explain to me what the differences are between cables for different bikes? I'm a little confuse d as to why these are so hard to come by...
If you remove the return cable it should work fine. I had the same problem then I removed the return cable and it works better than before. The spring on the throttle has more than enough tension to return the throttle.
BMX brake cables eh? That sounds pretty easy... Is this really viable? How hard is it to switch the cables out to bmx ones?
