CB360 Tires, Whats the widest that will fit?
  • Thread starter Thread starter blkcorvair
  • Start date Start date
haha thanks pj....youre vacuum adapters helped me out..i might have to send you my carbs for some air jet modding im running pods and a cm400 exhaust not sure if you can dyno test that combo? yeah i sold out because i just like the look of same size tyres...might have to find a wm3 rim sometime soon not riding aggressively but safety first right?
To save money if your using steel rims, you take the back one off and fit it to front wheel then get a cheaper steel rim for the rear.
I've used Yamaha XS650 steel rims on rear of CB360 without any problems but it's actually easier to get 18' XS650 alloy rims than the 18" steel
As for carbs, I no longer have access to a dyno, but, it doesn't matter too much as the carb mods are really for mid-range when jetting is right for top end.
Use a fairly long exhaust and you shouldn't have any problems (ends at rear axle or further back)
The shorter the exhaust the bigger the secondary main jets have to be and the worse the mid range richness gets
