Cb360 trouble splitting case, lower case stuck
CB360BT
Hi I am trying to split my case to fix the kickstart mechanism. I have all of the bolts out but I can't seem to seperate the lower case. What is this pin hanging out in the picture? It seems that this is a contributing factor to it not coming apart.
That pin holds in the splash guards and stays with the bottom half of the case. Chances are you're missing some bolts somewhere. There are a few small ones on the underside of the bottom case that can be elusive.
There is one bolt one top, in the back of the case, and 2 nearly dead center underneath. They often are missed.
Thanks guys. I'll be giving it a look again tonight after my shift, I know I didn't remove any from the opposing direction of the majority of the bolts. H
