sbaugz
DTT BOTM winner
So I am reworking my wiring harness and ran into a bit of a roadblock. I am using a universal left hand control setup and I seem to have mostly figured that side out. I am planning on purchasing a new right hand control unit to cover the kill switch and on/off switch aspect of it.
Now, I went over the wiring harness wire by wire and have identified most wires. The ones that are giving me problems are pictured below. I am just not sure how to wire all this with my new kill switch and on/off switch. On that same note- I haven't even purchased a new kill switch- on/off switch yet because I don't really know which would work best. I have checked out several mini bike switches on ebay for around $15 or so. Don't really want to spend $50+ on a switch from DCC. I would not be opposed to only using a kill switch and eliminating the on/off switch too but still don't really know what to do with all those extra wires.
Anyways, here is the breakdown of the wires I am having trouble figuring out what to do with:
They are:
White/yellow tube - goes to alternator from RH controls
Black/Yellow - LH control power that comes from fuse box via back/red wire from RH controls
Black/Red - goes from RH controls to fuse box, then to LH controls via black/ yellow wire
Yellow - goes to alternator from RH controls
Black/White - goes to coils from RH controls (assuming this would get wired to new kill switch?)
Brown/Blue - power to tach/ speedo lights coming from fuse box.
Black wire with 4 way connector.
several of those listed above go to and from the fuse box, but I am not clear what those colors are actually doing at the button controls on handlebars. Most of them go into the right hand controls but the wiring diagrams I have found don't really say specifically what each wire does at each switch in right hand control unit. My goal is to simplify the setup and simply have an on/off button and a kill switch on the right hand controls. ANy help would be appreciated. Thanks.
They are:
