cb360 woes
Akastus
Hey all!
Im working on a friends bike and was looking for a second opinion. He has a 1975 CB360t with free flowing exhaust and pods. The carbs are jetted up, synched, and the bike has ran decently well till recently.
Bike came to me with a weird idle issue. It would drop to really low rpms and the left side cylinder would not fire. Also at idle, it sounds like the engine would cut out every couple of seconds. When you give it gas, the left side fires right up, so the owner would just blip the throttle at lights. I opened the carbs to check the idle jet and the passages were clear. so i moved to checking the spark.
The left side had a real intermittent spark, so we ordered some 4 ohm coils from Emgo. I outfitted it with new wires, and new NGK caps. I also put new points in and replaced the condenser. No more intermittent spark! yay!
However, the left cylinder still wont burn unless you have the throttle cracked open a little. frustrated and vowing to have another crack at it another day, he left my house on the bike. Later he said the bike died 4 times on the way home. He then started it back up to go to school, and when he came out of class, the bike refused to start at all. I show up, and the headlight slowly fades out. Dead battery.
This has been the 3rd battery in 6 months.
So my question is this: will a crappy stator/regulator/rectifier cause the engine to run like crap? We will be replacing them just to rule out that being the issue, but am i missing something else? I feel like there is more to this issue. Any thoughts?
vacuum sync with a nice vacuum gauge synchronizer.
I just dont want to end up in the cycle of throwing parts at this thing, ya know?
ok did you cable synch the throttle plates first ? this will not effect idle but it must be done before vacum sink
I will check voltage when it gets here. Looks like he will be bringing it by this weekend once the parts come in.
Im not sure what you mean by cable synch the throttle plates. I did not do anything to the carbs prior to the vacuum synch, so the answer is no. I synched my old CL175 carbs (back when i had it) via the cables before, but those were VM carbs and this CB360 has the CV carbs.
Can you explain what you mean?
its pretty simple pull the carbs off the head,so you can see the throttle plate
then open the trhottle so there is a ,say 1/4" opening you can use the cable adjuster at the throttle grip to maintain the gap
use something to check that the gap is same at the throttle plate on each side like a rod or dowel whatever used kinda like a fat feeler gauge
adjust the cable housing AT the carb to get this gap even
once done then they are cable synched,this ensures smooth running when going down the rode,when not on the idle speed screws
the vacum synching is a seperate deal done at idle when ON the idle speed screws and in that situation there is always some slack in the cables
Ah! I get what you are talking about. I will definitely check that when it gets here. Thanks!
There is only one cable to the throttle. There is mechanical linkage connecting the two throttles and the cable moves that single linkage. That symptom of a cylinder dropping out is, as stated, either low voltage at idle, or a synchronization issue.
My experience on the CB360 is that a mechanical sync rarely works. Vacuum
sync is best. Use the special tool (Coaxial socket/screwdriver) to adjust so the locknut can be tightened without changing the adjustment. If you don't have it, amazon has it for about $15. Made by motion pro. Pic below.
What is the idle speed? 1200 RPM is minimum for decent running. Slower is a problem because you don;t generate enough. If you have a good battery but low voltage at idle, consider Sonreir's combo unit. Lower internal resistance and will provide more (hopefully enough) voltage at idle.
You also may need to readjust the idle mixture screw if you re-sync.
edit: Also, don't rule out a new vacuum leak....Check the manifolds, make sure the throttle shaft seals are im place on the outside seal, and lightly oiled on the inside seals.
EDit 2: I am assuming stock carbs...if you have mikuni's or non-CV carbs, than follow XB33's advice.
Alright so i fixed the issue. I replaced the regulator and rectifier with a new all in one unit, and replaced the stator with a good quality used one. Bike fired up and ran great!
Now its back. Right side cylinder is intermittent, and is shooting flames out of the exhaust. Pull the plug and its soaked. Replace plug with a new one to test and the cylinder comes back a little, but eventually starts doing it again. I pull the carbs and clean them real well, but its still doing it. check the points and timing, no dice, still does it.
Any thoughts? Ive replaced nearly every electrical component in the ignition line!
open exhaust and pods. Causing it to run rich between 2-4k. The reason it cuts out and fouls plugs.
Vacuum leaks, pilot circuit clogged and / or A/F mix out of adjustment. May be the reason it dies idling down.
What kind of condition are the diaphragms, slides and springs?
I bet she runs ok above 5krpm. What size secondaries did you install ?
Diaphragms, slides and springs all seem to be fine. Theres no holes in the diaphrams, the slides operate freely. Carbs were pulled back out and cleaned again.
I cant remember what secondarys i put in there for him, but i did get the carbs pretty well dialed in. For the most part, it ran fine up until this problem.
It seems to be running okay now. Fiddled with the timing again, and noticed the right side spark plug was half unscrewed... sigh, i really hope that wasn't the issue
Some times the simplest things are the hardest to find and the last thought on your mind.
well, i spoke too soon. bike runs great... until you really get on it. At WOT after a few seconds, it backfires (with accompanying flames) and there is a total loss of the right cylinder. Once you baby it, the cylinder comes back intermittently and then finally returns. Until you get on it again.
I'm stumped. I'm usually pretty good at figuring things out, but this has me baffled. Any possibility that its his valves and I've been looking at the wrong components this entire time? why would it be intermittent like that? I've checked to make sure that TDC of the piston stroke is in fact TDC on on the stator marks, so i know the timing hasn't jumped.
This bike has me seriously doubting my mechanical abilities! It also doesnt help that i am working a regular job, AND going to school, so time is limited for me to do that work
The timing marks on the stator match the timing marks on the crank, and will always be lined up. It doesn't have anything to do with the timing on the cam or the ignition, which needs to be verified. I would guess it's spark related and you should go over the timing procedure again.
Right cylinder timing out of whack. Set it straight, and no issues.
One thing ive learned over the years is to listen to others, because a lot of times ill overlook things i swear ive done (I call it tunnel vision). It takes just a few minutes to double check instead of assume. Thanks Sonreir for suggesting I double check that!
