CB360T, broken kickstart spring latch
cholland_
That small piece of metal is broken off where the kickstart return spring latches too. The kick start ratchets and stays up (you have to manually lift it up) when the engine is shut up, but when it's running it just flops around on top of the exhaust.
Anybody have any idea of a fix for this? Besides somehow welding that little piece of aluminum back into place, I'm wondering if it's feasible to drill and tap a bolt to hold it in place. Or should I just start looking for a new engine case?
Sorry, that's not actually the right picture (it shows everything in one piece). There was actually a bigger chunk from where the black 'stop' on the rod stops on the block. That C-shaped piece of metal that follows the curvature of the clutch is what broke off. I'll update the picture to show what's broken.
And umm... I guessed I kicked it? I'm really not sure how it happened either. I'm not a big dude.
Right now I'm looking for a new engine to scavenge the lower block from, and I've ordered the parts to get my starter in working order again. In the winter I'll tear the block apart, and see about drilling and tapping, if I haven't found a replacement yet.
