CB360t dropping cylinder during ride.
CaptainSaveAHo
Well. I've been fighting this problem for quite some time, and decided to reach out for help. I've done all the preliminary work... It's the left cylinder, I have spark while in the garage, I have no blockage in the fuel petcock or lines. Its seems to run fine until I take off hard, or run highway speeds for a mile or so. After apologetically getting out of everyone's way, I baby it, and I get the cylinder back. It would die if I let it, but I can throttle it up till the issue passes. WTF is going on?
Sounds like when you run it hard, it is sucking fuel out of the float bowl faster than it is flowing in. Look for something restricting flow to the carb.
There is a little screen on the float needle seat where fuel enters the float bowl on most carbs. That can get clogged. I'd just about bet that is your problem. The float needle seat itself could be clogged, too.
Get your self a manual, the shop manual is in pdf format and find-able free in a few places. Checking the float level is as explained in the manual, some find it better to do ON the bike since you can use the fuel the tell you when it does actually open. Will make a mess though. I have had issues with OLD float valves, the springs in them will wear out over time and cause the level of fuel in the bowls to be higher by about a 1MM or more. Will cause the bike to run richer and flood, doesn't sound like your issue but I would recommend getting a rebuild kit just for that reason, if you can get just the valves do so.
Another thing you might try, is pull over right as soon as it does it, shut the bike down and POP the gas cap. If you hear a POP or a rush of air then there is a good chance the vent in the cap is plugged.
As a SIDE Note, would love to see a few pictures of your air cleaner configuration... :o
Frogman, there are two factors here that suggest that you are on the wrong track.
1.) Left cylinder runs at idle or low load, and runs normally at higher throttle for a few seconds before it starves of fuel. If float level was low, it would not recover when he "babies" it. It would starve of fuel all the time.
2.) Poor venting of the gas tank doesn't appear that quickly, and it would affect both carburetors equally.
Everything the OP described indicates restriction of flow to one carburetor.
Check carb sync.
ADC is probably right about fuel flow but wrong about screen on shut off valve (that's on Mikuni's)
Fuel tap has dual outlets, one side could be restricted
Did you re-jet for the pods?
try 105~115 secondary main jets
Set float level at 20~21mm instead of 19mm stock.
There is also a mesh screen on the fuel tap, remove the bowl on the bottom (10mm nut end) and look inside.
The sealing 'O' ring will hold it in place.
If it's missing or damaged it will let crap from tank into carbs
Check fuel flow by draining tank into a clean bucket, (through the fuel lines you using-disconnect from float bowl)
That will tell you is there is a restriction one side.
The in tank filter is real difficult to remove without damaging it, try Honda for a new one, I think it's a more or less 'stock' part on newer bikes (250/400 range)
Could also be gummed up jets, common for left side if bike is normally parked on sidestand
Wow, I thought I was a dumbass for not knowing this one, but i guess there are a few things I still need to check. I did actually drain the tank via the fuel lines into a gas can. Both hoses seem to have the same flow rate. After getting most of the gas out, I took the petcock off and found some debris, but not nearly enough to cause what I've been experiencing. On the carbs, a full rebuild has already been done, and a 115 jet is being used. Float height may still be an issue, and is understood. I just really hope the pack on the left side isn't the reason. Is there a possibility that it could be electrical?
As a side note, while I'm "babying" it it will backfire when I take it up to 5k rpm.
Will take pics of air cleaner setup. Thanks Guys!
115 may be too big, depending on exhaust restrictions?
It will be rich mid range
Have you changed condensers, they could be bad when hot?.
It could also be ignition coil breaking down when hot
Float height is critical when pods are fitted
Ok, not that i've given up, but i don't have as much time as I used to. I dropped it off at my local bike shop a week ago, and they mentioned the valves had little clearance. I drove it to day, and much to my disappointment, it dropped the cylinder again. The bike was cold, and the symptom came within 3 blocks, and 65mph. So, I'm looking electrical, I guess. This thing is getting to the point where it's overall cost is not worth the trouble.
And as always, I'm glad this site is here and grateful for your help.
Sorry i haven't taken pics of the filter setup yet because it's not home yet....grrrr.
That's the problem with old bikes.
If you can't work on it yourself, you need to find someone who was around working on them 'back in the day'.
As 360 wasn't particularly popular even when new, chances of finding someone who understands them (other than me) is pretty slim.
Shop may have set valve clearance too wide, whatever, they didn't fix the original complaint so your quite justified to take it back and demand they fix it
It is a simple system, shouldn't take too long to do electrical and fuel tests, 30~45 mins
If you were near Orlando I would take a look at it
Or anywhere around someone that has one... I would look it over for the fun of it. Just did a tune up on mine since it needed points filed, reset and timed, advancer worked over, and all that and it always seems like a new bike when I do, shouldn't wait so long to do it I guess. ::)
I had very similar symptoms and during the carb clean my guy found that one of the carb diaphragms had tears in it. My replacements haven't gotten here yet but I'll let you know how it goes...
Thanks for the opportunity for the lookovers, I live in NorthWest Illinois. If anybody is nearby, I'm game. I noticed there aren't many folk in my area lookin to cafe their bikes.
Got it back from the shop, and they had replaced the coils, the guy did both since the mounting bracket changed and couldn't support the old and new coils. Meh, whatever, 75 bucks and I'm sure he took a loss in all the time he spent chasing it.
The bike runs pretty well now, but it's been cool/cold here, keeping the bikes temp down. I did take it on highway for a short 5 mile ride at 70+ mph. It seemed good at that sustained throttle. But just as I was hitting the off-ramp it started getting a little short of power. And last night, I was cruisin at 65mph, and as I was getting on the off-ramp, I pulled in the clutch to idle toward the stop and the bike straight up died on the roll. I don't think I did anything wrong, but please tell me if I did. It was cold out (39F). Bike started right up at the stop sign.
It seems when there's high demand for fuel, it's great, and the immediate drop of throttle just plugs/floods up. Float height?
The air cleaner setup. Went to lowes and got a 45 degree rubber coupler to negotiate between the carb and the aftermarket cone filter. It's not perfect, I have to shift the cones further apart to acomadate the battery box.
